    Oct 2016
    Can I go to narrow wide?
    I am an outdoor education teacher and I manage a fleet of 15 2015 Specialized Rockhoppers. I have taken the front derailer off and the kids have really excelled in with a 1x drive train. Let chain break, suck, cross chaining...
    The bikes are a nine speed set up and at the moment I am looking at narrow wide chain rings.
    Will a narrow wide chain ring work with a nine speed chain and cassette? Some of them are speed specific but others do not mention if they are speed specific.
    Reputation: Joules's Avatar
    I'm not aware of a n/w ring designed for <10s. That's not to say they won't work - the teeth are just going to be slightly narrower than ideal. And when I say slightly, I mean slightly, as in the equivalent of a month or wear.
    To me the bigger thing is the fact that there's no such thing as a 9s clutch derailleur. That makes much more of a difference in terms of dropped chains.
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Quote Originally Posted by El'Gator View Post
    I use a narrow wide on my 1x9. I think it was a raceface chainring (*Race Face Single Narrow Wide Chainring > Components > Drivetrain > Chainrings | Jenson USA). I use a 9spd chain and have no problems with noise or derailing of chain without a clutch rear derailleur. I use a n-gear jumpstop (N-Gear, Home of the Jump Stop) with a bashguard just in case but I took the jump stop off awhile ago to test something and never put it back on and haven't had any drops.
    Try this: HTFU
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    The inner width of a 9/10/11/12 speed chain is the same, so a 10 speed narrow/wide chainring should work just fine.
    I have clutch dirrailleurs on my setups, and sometimes I forgot to turn them on, and I only know that I had forgot to turn the clutch on its because of the noise, not once the chain droped because I forgot to turn the clutch on, believe it or not a narrow/wide chainring will do more to prevent a chain drop than a clutch dirrailleur.
    If you gonna buy them in bulk and I guessing you want something that will last, get a SRAM N/W steel chainring, they are at 4.99 on ChainReaction. The only problem is that your crank has to be 94BCD.
    P.S.- I checked the bike specs and it seems that the bike have a 10speed chain from stock.
  1. 64 BCD Narrow-Wide?
    By IPunchCholla in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2015, 11:30 PM
  2. Replies: 10
    Last Post: 05-27-2015, 01:37 PM
  3. What is narrow wide?
    By nate. in forum General Discussion
    Last Post: 12-18-2014, 10:44 PM
  4. Replies: 1
    Last Post: 08-12-2014, 09:06 PM
  5. narrow-wide for ss use?
    By leider in forum Singlespeed
    Last Post: 04-22-2014, 07:22 PM
