Results 1 to 6 of 6
    *Hotter than Hell*
    Aug 2005
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Sure, If you want....
    Those shifters have been around for 2 years.
    They also re-introduced canti brakes so you could have a complete build.
    While none of it is specifically designed for MTB it would all work fine.
    It is intended for a flat bar road bike.
    I bike; therefore, I work
    Doesn't Matter
    It'll work fine for a flatbar MTB application if you want.
    Dura-Ace barcons are intended for TT use but plenty of people see fit to combine them with Pauls mounts and use them off road.
    Quote Originally Posted by Shayne
    Brakes could be a problem- from the location of the pivot it does not appear that they will work with linear pull brakes (v-brake) - would have to be some type of cantilever brake or maybe the road version of the avid mechanical disc brake.
    Yup, Cantis
    Campagnolo also has re-introduced cantilevers as has Shimano and Avid still make some.
    No problem there.
    They work just was well as linear pull brakes; Cantis disappeared do to marketing and Shimano...just like the square taper crankset.
