Results 1 to 2 of 2
    Reputation: Slyp Dawg's Avatar
    Oct 2007
    Calling all Middleburn Duo ISIS/Square Taper users: chainline to INNER chainring?
    I've got an ISIS spline set of Middleburn RS7s running on a 113x73mm BB, and I am having a hell of a time getting the chainline anything close to the middle of the cassette without needing 7mm worth of spacers (calculated chainline to the middle of the cassette is ~43.5mm as per the calculations on Sheldon Brown's website), and I've been looking to put a smaller chainring on it (currently have a 32t). I know the Duo offsets the inner ring in a bit to give a 50mm chainline for the two chainrings, but nobody seems to have ever mentioned how much offset that amounts to. I tend to spend a lot of time in the lower gears (1-5 when climbing with a 32t and frequently end up mashing 1st up hills) so I'd like to bias the chainline towards the middle or lower end of the cassette, would I be able to get anywhere near a ~44-46mm chainline running just a Duo inner ring/spider? I'm fairly confident I won't run into chainstay clearance issues with that low of a chainline and a fairly small chainring (27t or 29t), my main concern is actually being able to get the chainline in where I want/need it to get good shifting performance in the lower gears
    Quote Originally Posted by teamdicky View Post
    My butthole would pucker and invert until I was inside-out before I got to the bottom.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Can't give u numbers but when I ran a Duo with the same setup, I had no problems shifting in the low gears.
  1. Square taper BB?
    By Nater in forum Fat bikes
    Last Post: 10-14-2013, 05:24 PM
  2. Middleburn Uno Users?
    By raganwald in forum Singlespeed
    Last Post: 07-23-2013, 12:34 PM
  3. Square taper chainline help
    By Mr Pink57 in forum Singlespeed
    Last Post: 05-02-2012, 02:45 PM
  4. Middleburn, home brew spiderless... chainline.
    By h2otaco in forum General Discussion
    Last Post: 02-04-2012, 03:09 PM
  5. 2x9: Middleburn RS8 ISIS Duo = 522g (no BB)
    By Cheers! in forum Weight Weenies
    Last Post: 01-07-2011, 06:45 PM
