Results 1 to 8 of 8
Thread: cables and lube
    cables and lube
    Hello everyone; can somebody tell me if I can use DRY teflon lube from finish line, to lube my shifter cables or what other lube can I use to keep them clean, same thing for the brake joins
    Reputation: Carraig042's Avatar
    I use dry lube for my cables. Have not had a problem, keeps them quiet and smooth.
    -Brett
    Visit my Youtube channel for lots of DH and XC videos!
    2014 Devinci Troy Carbon
    2011 Spec Demo 8
    GoPro HD Hero
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by kukulkan
    I use full length housing when possible, Teflon coated cables and no lube.
    Do not think I have used any lube on cables for nearly 15 years.
    mtbtires.com
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    My experience with lubing cables has not been good. That may be because the trails I ride are very dusty though. They eventually collect dust and gum up. I get better, longer lasting, shifting from full-length housing with no lube other than what came on the cables. I wouldn't use dry teflon lube under the same conditions.
    i use sailkote but only on the cheapo bikes that i work on. i also only use it when it is necessary.
    Most likely is better to use full length cables then, OK everybody thanks for all the input . any particular brand of Teflon coated cables ?.
    Reputation: Cata1yst's Avatar
    I dunno how much teflon coated calbing is, but you might wanna check out that fibourous stuff... supposedly it wont stretch whatsoever.
    Lean back, Hit both brakes, And ask yourself, Do you feel lucky today?
    Reputation: masterofnone's Avatar
    I've given up lubing cables. If you need to lube your cables it's time to replace them and the housings. Full length housings are awesome, I have some bikes with full housings than can go almost two years before it's time for new.
