Results 1 to 19 of 19
    Five is right out
    Cable routing - too long?
    Does this cable routing look too long?
    My LBS just swapped out the long cage X.9 for a short cage, top-normal, XT derailleur. Looks like replaced the cable and housing while they were at it.
    Shifting is now noticeably sluggish- the shifters feel like mush. Is this something inherent in XT shifters (if so, I don't remember it from my XT shifters of several years ago), is it the cable length, or is it likely something else?
    On MTBR hiatus :(
    Wow. Compared to the direct cable routing of the SRAM, yeah, that's a lot. You've got a little room to shorten it, but if that loop gets too much tighter, you'll begin to feel the friction.
    Ever tried a Rollamajig? They're not too expensive, probably worth a try in your case. I like 'em to get rid of the Shimano loop.
    Looks like a hamster nibbled at your seatstays and they're starting to rot. Does that result in any rear wheel travel?
    speedub.nate
    MTBR Hiatus UFN
    Five is right out
    Quote Originally Posted by Speedub.Nate
    Dammnit, I knew I shoulda kept Huey the Hamster in his cage!
    I'll have a look for these rolliathingies. You're right- just shortening the cable is going to kink something silly.
    On MTBR hiatus :(
    Quote Originally Posted by womble
    But seriously, about those chainstay thingies... is that what they do?
    speedub.nate
    MTBR Hiatus UFN
    Reputation: shiggy's Avatar
    Dec 1998
    They are a ti pivotless pivot.
    mtbtires.com
    Five is right out
    Ah, if you mean those skinny black bits, they're carbon fibre 'pivots' that flex a bit with suspension movement. One of the distinctive features of a Yeti 575 frame.
    I'd somehow managed to overlook them when buying the frame, and would have had second thoughts had I known about them beforehand as I can be a right Luddite sometimes. However, they're reputed to be highly reliable so it's fine.
    PS: I just ordered a Rollimajig. Now that you've pointed it out, the cable run with the new derailler is pretty horrible.
    On MTBR hiatus :(
    Ah! I can't tell you how many 575s I've looked at, and I've never noticed those before. Hmmm...
    speedub.nate
    MTBR Hiatus UFN
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    good call on the Rollmajig... it will improve the shifting "crispness" :P
    <a href="http://www.flickr.com/photos/cmadrigal/369314866/" title="Photo Sharing"><img src="http://farm1.static.flickr.com/159/369314866_bcd4d2af5d_o.jpg" width="600" height="800" alt="M-761 xt derailleur on 575" /></a>
    Five is right out
    I only noticed mine after reading mention of it on these forums
    Duh!
    On MTBR hiatus :(
    Quote Originally Posted by crisillo
    I was wondering how that was going to play out with the chainstay cable routing.
    That cable entry looks a little "bent" -- does it work ok?
    speedub.nate
    MTBR Hiatus UFN
    that was dummy me...that installed the Rollmajig "reversed" and took a pic (you can't see the Avid logo on the pic above) I realized this right away and fixed it..but didn't take another pic
    you can see how it turned out in this one
    <a href="http://www.flickr.com/photos/cmadrigal/517562222/" title="Photo Sharing"><img src="http://farm1.static.flickr.com/253/517562222_1a2b3e8e06_o.jpg" width="1280" height="960" alt="575 resting against a tree" /></a>
    I might give the shadow XT a try eventually though...
    Five is right out
    Good to know that was an older photo- kind of freaky if your drivetrain was usually that clean
    that was a very unusual pic... it looks like the second pic most of the time...
    Reputation: Jesterrider's Avatar
    I went to Nokon cables 2 winters ago for my rear der. It was $50 to get the MTB set, but the rear lasted 2 years, one of which included brutal Oregon wet winter riding. I replaced the inner cable housing and actual steel cable this summer just because I assumed it must be time to replace it, not due to any issue. Since I only did the rear and the housing does not wear out, I had everything I needed to redo the rear without buying anything. Voila' 4 years of flawless rear der function for $50.
    that being said, I need lots less cable around pivots and leading to the derailleur itself. I used to experience some ghost shifting due to suspension travel, which is why I tried Nokon in the beginning. It fixed all of that. It took some time initially to set it up and find the optimal lengths for the sections, but it's all good now. I never lube the cable, only the housing once in a while.
    Five is right out
    Shadow XT?
    Quote Originally Posted by Jesterrider
    but it can be expensive in the 575 because it is made for a full housing run.... so one would need one or 2 expansion packs to make the full run besides the standard kit...
    Shadow XT?
    yep.. the 08 shadox XT RD
    I was very leery of this Rollamag thing but I finally broke down and tried it. It works well. It did reduce my shifting drag slightly but what really improved was my shifting accuracy. Every gear is exact and crisp now.
    See pics and my small story in here...
    Do thumb shifters wear out?
