Results 1 to 3 of 3
    May 2005
    Bumps causing shifts
    I've been learning wrenching on my own, and after replacing my shift cables, my bike "shifts" on its own when I hit bumps. It doesn't actually change gears it just tries to until the suspension comes back to its normal position.
    Otherwise, it shifts beautifully.
    What did I do?
    Boyeeee
    Reputation: BCBlur's Avatar
    Sounds like you might not have enough housing running along your linkage.
    Try adding more housing to the piece of cable that is affected by your suspension movement.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Quote Originally Posted by BCBlur
    I agree and sometimes it is the loop that is at the back of the rear triangle that connects to the rear of the derailleur that is the one that is too short. Make sure that loop is kinda on the big side. I have seen this many times and you wouldn't necessarily think that part of the housing would be the culprit, but it is.
  1. What's causing my pad wear?
    By BigLarry in forum Brake Time
    Last Post: 04-05-2005, 03:23 PM
  2. Miss shifts in spite of adjustmts
    By HTail in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2005, 10:11 PM
  3. Shop replaced rear derailure now bike shifts horribly and shop feeds me Bs
    By mikeyp187 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-14-2004, 12:36 PM
  4. Shaving - Avoiding razer 'bumps'
    By DobeManSS in forum General Discussion
    Last Post: 07-14-2004, 11:32 AM
  5. Stylo SS flex causing a creeking sound?
    By MrXC in forum Singlespeed
    Last Post: 04-29-2004, 11:05 AM
