Results 1 to 3 of 3
    Broken kmc x10 chain. It was my fault. But yave a question
    When I got my new sl10x chain i automaticly took 3 links out before even tryig it on the bike. It turned out to be a bit to short for my liking and put the links back in. Few months after and countless miles (and 2 or 3 races) it broke while I had a good lead for first place. Bummer. Sure enough it broke where I was messing with it.
    Is a chain garbage i a link is pressed out and back in. Do I just buy another quick link to replace the pin. I did put it back together and it was fine for a few hours of riding.
    Or is there a way to slightly mushroom the end of the pin. It has nice resistance when pushed back in but Mabye I was just mashing on it to hard.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Regular pins are not meant to be pushed back in. Eventually they will fail at that spot, as you found out.
    You can put a quick link in place, or shimano has pins meant to be pushed back in, not sure if they are compatible with KMC chains though.
    Yea I saw the shimano pins. I wasnt sure if they would work. I guess anothe quick link i the better option then leaving the pin in. When I put it back together I was worried it would come back to haunt me. Sucks it waited till I was on my way to my first win of the year.
