Results 1 to 9 of 9
    Reputation: Dallasrebar's Avatar
    Brand new and busted
    Is this normal?
    I just bought this on ebay and that's probably my first mistake. X9 crankset. Is it normal for the teeth to be chipped and uneven fresh out the box?
    And I guess more importantly, will it affect the ride? I still have the option to return these but wanted to get some opinions first. This is my first crank purchase.
    Does anyone ride with worn teeth worse than this without problems or should I return these and buy from my LBS?
    Attached Thumbnails Attached Thumbnails Brand new and busted-_ctp8764-edit.jpg
    Tá mé ar meisce.
    Reputation: BeerCan's Avatar
    I don't think it is busted at all. I believe the teeth are that way to aid in shifting performance.
    To see what is right, and not to do it, is want of courage or of principle. -- Confucius
    Come join me at the Swamp
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Not to worry. Those all support shifting.
    That said, rmember when you remove the rings that you orient them in the same way when you put them back.
    I don't rattle.
    ride more
    They are supposed to be like that
    Reputation: marpilli's Avatar
    I wondered the same thing when I first inspected my chain rings.
    BTW, hello from the far north of the metroplex.
    meow meow
    Reputation: b-kul's Avatar
    its all good
    Nov 2008
    The cut and sculpted teeth make it easier for the chain to dis-engage and switch to the other chainring.
    fb
    www.chain-L.com
    The key to solving any problem is to understand and address the underlying cause.
    Yes - its normal for the teeth to be different lengths (as others have mentioned
    Yes - it will affect your ride. It should vastly improve it to have smoother shifting gears
    thanks for all the replies. I found a video and link to Sram's chainring design.
    www .sram.com/truvativ/technologies/360
    www .pinkbike.com/news/SRAM-XO-drive-train-tested-2011.html
  1. Brand names vs less known brand frames
    By Dictatorsaurus in forum Bike and Frame discussion
    Last Post: 12-22-2009, 09:18 AM
  2. Spot Brand 29" SPAM brand new...
    By Miker J in forum Singlespeed
    Last Post: 05-22-2007, 07:25 AM
  3. Brand new bike, Brand new Fox Float RL fork
    By uribt in forum Shocks and Suspension
    Last Post: 03-31-2005, 01:10 PM
  4. Store brand versus national brand
    By SpinWheelz in forum Where are the Best Deals?
    Last Post: 08-13-2004, 06:25 AM
