    Powered by ice cream.
    Reputation: Enel's Avatar
    Brake housing for derailleurs
    Anyone else having good luck with this combo?
    I have been using it with great success on my Sram Grip shift set up. Just FYI. I think the brake housing is slightly heavier which is the only significant difference I can find in performance.
    neutiquam erro
    Reputation: Chris130's Avatar
    Mar 2005
    Because it's spiral-wound (versus longitudinally), it could lead to mis-shifts. That's the usual argument why not to use brake cable on derailluers.
    I figure they are different for some good reason, so I keep 'em matched to their intended use. But if it works for you, have a nut!
    Cheers, Chris
    Now is the time on Sprockets when we hammer.
    '05 Blur Classic (1x9) || '06 SIR9 (SS) || '06 Brompton P6L
    Retrograde Customs
    Reputation: dansjustchillin's Avatar
    Brake housing is not stiff enough for index shifting.
    Retrograde Customs
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Yup
    I've used it from time to time with good results.
    In my experience once "broken in" it shifts no different than actual derailleur housing. It will compress a bit and you re-tune your shifting just as you would with cable stretch on new cables.
