Results 1 to 5 of 5
    Aug 2010
    Which bottom brackets fit XTR M950 cranks?
    Other than the XTR M950 bottom bracket, which others will fit the M950 cranks?
    Is there an external bearing bottom bracket that will work?
    Plays with tools
    Reputation: customfab's Avatar
    Your pretty much stuck buying an XTR V1 splined BB. The XT and lower BB's wont work because they used the V2 spline.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Also known as Octalink v1- BB-M950 or BB-M952 are my preference. Note: be very careful when installing crank arms on the BB to make sure the splines line up properly before tightening otherwise you can munch either or both the crank arm or BB splines. I move the crank arms back and forth a bit when installing to make sure they are on all the way before tightening.
    Reputation: Nater's Avatar
    Quote Originally Posted by jabrabu View Post
    Former Bike Wrench
    You can also use Shimano Road Octalink BB's depending on what chainline your after.
  1. 8 speed cranks and bottom brackets?
    By taprsnap8888 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-03-2009, 01:38 PM
  2. Quite a few questions about cranks, bottom brackets, future designs, etc.
    By Roasted in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-13-2009, 06:35 AM
  3. Replies: 11
    Last Post: 02-24-2006, 11:30 AM
  4. Cook Bros Bottom Brackets / Cranks ?
    By lanpope in forum Vintage, Retro, Classic
    Last Post: 01-02-2006, 12:35 PM
  5. Replies: 2
    Last Post: 06-22-2004, 11:06 AM
