Results 1 to 2 of 2
    I plead the fizif
    Reputation: TronCarter's Avatar
    Bottom Bracket Recommendation?
    I have an '07 Gary Fisher Wahoo that the bottom bracket has gone bad. I need some recommendations on a replacement. Money is a little tight right now, so I don't really want to spend more than maybe $50. The old square taper BB says:
    Middus
    Sealed ball bearing CARTRIDGE
    BC-73ET
    73
    BC 1.37x24T
    VP Components
    L <-- 124.5mm --> R
    I don't want to replace the cranks, etc if possible at this time, so I would like something that would be a direct replacement.
    Tron
    Former Bike Wrench
    Well Shimano recommends a 122.5mm spindle, so I would go with that. A UN26 will work fine for around $12 or a UN54 will probably outlive the crankset for about $24
