Results 1 to 6 of 6
    Bottom bracket/frame question
    What are people using on external cup threads during assembly? I have always used grease (I like Parks ) but have also heard of folks using antiseize compound or even Locktite. The Locktite kind of scares me, never have had one loosen personally. The reason I ask is last year I took the cups (Shimano XT) out of an older Superlight frame (aluminum), and the threads on the cups were pitted. I installed them with grease approximately 1.5 years prior. Also, there was water in the frame around the spindle of the crank. Most of the trails I ride have water crossings, most about a foot deep. I don't so much care about the cups but I don't want to mess up my frame. A couple of years ago a had an old bottom bracket stuck in my old Cannondale gravel bike and it was a less than fun time getting it out!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Dr.Mushy View Post
    Grease. Just grease.
    mtbtires.com
    Plays with tools
    Reputation: customfab's Avatar
    I always use anti seize on anything threaded. It's nice for bikes because you are commonly putting dis-similar metals together, which can often gall. Just apply it sparingly as it can make a mess in a hurry. Anti-seize for titanium parts is mandatory btw. A lot of BB's come with some kind of thread retainer factory installed as well.
    Aluminum is a very dirty metal, it likes to oxidize at the first sign of atmosphere.
    http://www.abbeybiketools.com/
    --- industry disclaimer ---
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    If you are squeak paranoid or suffered with long term symptoms in the past, you could wrap a thin layer of teflon tape on the threads along with a bit of grease.
    I've done it both ways and haven't had a stuck BB so far (after a lot of steam crossings that dunked BB's and even completely submerged chain rings at times).
    I have always used grease on all bolts/threads in the past but the galling on those cups kind of got me going (I love my old Superlight.) I have heard about antiseize on titanium but I'm too cheap and heavy to own any of those metal bits! I used to use antiseize on the seatpost of an old roadbike that wanted to get stuck and it worked better than grease in that application. I used a hacksaw blade, a chisel,a hammer and the magic words to get the shell out of my Cannondale and the thought of doing that to said Superlight makes me sad.
    I tried everything from teflon tape to antisieze to grease...
    I got fed up with the sqeaking so I used JB weld ...
    That worked...I just change the bearings on the bike.
  1. Jet 9 RDO - bottom bracket question
    By slim2none in forum Niner Bikes
    Last Post: 05-09-2013, 07:51 PM
  2. Replies: 16
    Last Post: 12-01-2011, 01:47 PM
  3. Custom frame bottom bracket question (PF30 vs standard)
    By pwd81 in forum Custom Builders & Other Manufacturers
    Last Post: 11-16-2011, 01:25 PM
  4. Bottom Bracket Question
    By swell6 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-07-2011, 07:28 PM
  5. Bottom bracket question
    By sprknranger in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-01-2011, 03:40 PM
Hot Deals
Contests
Latest Mountain Bike Articles
