    May 2005
    Bottom Bracket on F1000
    I have owned a 2003 F1000 Optimo frame.
    I have mounted a XT triple Crankset with a bottom braket Hollowtech 68 x 113mm.
    I have a 9 gears cassette 11-34 on my rear wheel.
    After trying to set my derailleurs I saw that the chain line was not really ok. It seemas that the crankset is a bit to far from the frame.
    Could someone tell what is the good bottom bracket length for this frame. 110 or 107mm ?
    Reputation: logbiter's Avatar
    try a spacer or two on the non drive BB flange to move it over a bit.
    I'm not very familiar w/ hollowtech stuff, but you may not be able to get a shorter spindle, post the model # of your crank, and you can get some better info.
    Quote Originally Posted by airjek
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    BB Spindle is based on crank, not frame
    There should be 2 possible BB spindle lengths for that crankset. If you go to the Shimano website armed with the crank model number you can find the recommend BB spindle lenghts.
    May 2005
    I can't find the information on shimano website, made different searches by different method but nothing...
    Here are the specs of the crankset and the bottom.
    Shimano XT FC-M751 Crankset Hollowtech
    ES70 Bottom Bracket 68 x 113mm
    Thanks again to help me.
  1. monocog bottom bracket question...
    By homestar in forum Singlespeed
    Last Post: 11-15-2005, 08:59 PM
  2. which bottom bracket size?
    By Jaker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-04-2005, 11:04 AM
  3. bottom bracket type??
    By Styles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2004, 10:06 AM
  4. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  5. Help with bottom bracket
    By DoothaBartman in forum General Discussion
    Last Post: 04-10-2004, 02:44 PM
