Results 1 to 8 of 8
    Cycologist
    Reputation: chazpat's Avatar
    Bottom Bracket Blues
    When I tighten the cup on my bottom bracket, there is about a 3/16” gap between the inner side of the ring on the cup and the frame. I have a spacer but it is only about 1/8” so I have an extra 1/16” that it can move around in. Does this mean I have the wrong width bottom bracket? Can I just get a 1/16” spacer from my LBS? I’ve ridden it this way and it seems fine, just came across it as I was taking the crank and cup off and cleaning them as I have a gritty sound when pedaling and I’m wondering if this slop is allowing grit in.
    thanks!
    chaz
    Reputation: ghettocop's Avatar
    This is an external BB? What is the shell width of your frame? 68 or 73? Is the 3/16th gap equal all the way around the shell or just in some areas?
    Cycologist
    Ah yes, it's coming back to me now, 73 without the spacer and 68 with. It is not an external, it is a first generation Superlight. The gap is equal around. So maybe I have some buggered threads and need to get my LBS to chase it?
    chaz
    Reputation: Nater's Avatar
    You say it's not external, but you don't tell us what kind of BB it actually is. I'm assuming that Superlight is the bike model?
    There are some ISIS BBs out there that rely on a rubber o-ring to take up the space between the frame and the NDS cup.
    Cycologist
    It is a 2001 Santa Cruz Superlight; ISIS BB that came on a Race Face crankset, I forget what model but it is several years old, maybe 4 or 5 years.
    chaz
    Reputation: MikeBurnsie's Avatar
    Jan 2011
    I have an older Iron Horse that uses an Isis drive BB, Gigapipe SL. I just replaced mine and it came with an O-ring to take up the gap.
    2016 Transition Patrol
    2011 Stump Jumper
    2018 NukeProof Scout
    ups and downs
    With a Race Face ISIS BB, a 68mm shell would have two 2.5mm spacers drive side and one 2.5mm spacer on the non drive side, a 73mm BB shell would just have one 2.5mm spacer on the drive side.
    Cycologist
    ok, hauled it over to my LBS, mechanic took a quick glance at it and said the bottom bracket was screwed in too far. Correct install is to install bb part way, install the cup (and spacer if a 73mm) all the way in flush, then finish screwing in the bb, yes, with a little thread sticking out.
    chaz
  1. CK bottom bracket
    By Nelson34 in forum Fat bikes
    Last Post: 01-08-2013, 06:39 AM
  2. which bottom bracket?
    By tomboyjr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-05-2012, 07:41 AM
  3. Bottom Bracket - what would you buy for your yo
    By Duc-Duc-Guzzi in forum Vintage, Retro, Classic
    Last Post: 10-29-2011, 08:09 PM
  4. Bottom Bracket?
    By loOse1 in forum Fat bikes
    Last Post: 10-25-2011, 06:44 AM
  5. Bottom Bracket ?
    By zindog in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-09-2011, 02:50 PM
