Results 1 to 6 of 6
    thread crapper
    BMX cranks/BB on MTB
    So, I have a buddy that rides a lot of BMX and wants to build up a MTB with some of his parts laying around. Can you run a Euro BMX BB on a MTB?
    Former Bike Wrench
    Aren't Euro BMX and ISO the same...its been a few years but I believe they are the same 1.37" x 24 tpi
    thread crapper
    From what a mechanic has told us it should work, in theory... He worries that it won't fit ideally and could cause added wear on the bearings.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by scottap2003 View Post
    BMX Euro is the same as mtb threaded english. No difference at all, except some mtb shells are 73mm wide rather than 68. A Profile-type BB just needs a different bearing spacer.
    mtbtires.com
    absolutely, euro BB with a 19 mm bmx spindle. you can run a spider to most BMX cranks to run a MTB chainring if your going to do a chain guide and gears. but most newer DJ frames use press in BB bearings just like BMX. integrated headsets too. MTBMX! lol
    Reputation: Fix the Spade's Avatar
    Slightly tangental this:
    You can press Spanish BB bearings into Shimano Hollowtech II cups to make a 19mm axle fit bottom bracket for mtbs. I've had a lot more sucess with this than using Euro size BMX bbs as they tend to be kinda weedy and vulnerable to mud/water ingress.
    A few manufacturers are making off the shelf versions too now, Deity and Profile certainly have them available.
  1. 09 Shimano Saints or Race Face Diabolus cranks Cranks?
    By RidingRiot in forum Downhill - Freeride
    Last Post: 03-16-2009, 07:23 PM
  2. Shimano FC-M970 XTR HollowTech II Cranks: 08 cranks same as 09?
    By ThePunisher in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2008, 06:24 AM
  3. Morati Titanium cranks. difference between mtb and road cranks?
    By ozbmx in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2007, 08:44 AM
  4. Shimano Saint cranks vs. Hone cranks??
    By dementedfatty in forum Clydesdales/Tall Riders
    Last Post: 07-31-2007, 08:51 PM
  5. Is there any benifits going to 170mm cranks from 175mm cranks?
    By drumstix in forum Downhill - Freeride
    Last Post: 12-07-2004, 08:24 PM
