Results 1 to 9 of 9
    Reputation: Spork n' Beans's Avatar
    Bearings for Time ATAC XS?
    Does anybody know where to find replacement bearings for Time ATAC XS pedals? I talked with the guys at Universal Cycles about their Enduro kit, but as near as either of us could tell, this was a replacement set for the older style ATACs. They looked through their catalog from Time & couldn't find any bearing kits (they found just about every other part to rebuild them).
    I replaced the bearings about 18 months ago through an LBS (since outta business), and the pedals have now developed a lot of play. I'm thinking it's 'time' again, but I'd just as soon do it myself. Anyone know where to buy them?
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Have you checked the Time USA distributors?
    http://www.time-sport.com/us/home.htm
    Time's website is only slightly better than Rockshox's
    The Time website has pretty much no useful info. The best you can get is:
    http://www.time-sport.com/pdf/not/xsalium.pdf which amounts to instructions for mounting cleats to shoes. Umm, thanks Time.
    Resource for finding bearing sizes used in bikes
    Boca Bearings List the bearings used in bikes - use advanced search under manufacturer & model search - select bicycle kits.....
    Or just enter the following in search & hit submit.
    You shd find kit #BRK-027C-YS/C3 for this. This is a kit for 2 brgs 608 size 8x22x7.
    Good idea to make sure that the brg that you are removing matches with the ones that you are buying.
    Expensive bearings!
    Thanks for the link. I saw this the other day when I was looking, but didn't understand how to get the detailed information on sizes (608--8x22x7).
    I'm not all that hip on spending $35 on ceramic bearings for a set of pedals, but this should at least tell me what I'm looking for.
    Muchas gracias!
    Regular 608 brg
    Sure - undertstandable. Try the MR608-2RS (8x22x7) $ 3.75 each free shipping no minimums
    The bearings listed by bearing man, are for the old Time ATAC...not the newer Time ATAC XS. I just took delivery of 2 sets and they are clearly too large.
    For time ATAC XS you are looking at: 6mm x 15mm x 5mm
    bt
    bt is offline
    Nov 2007
    Quote Originally Posted by Spork n' Beans View Post
    um...wow!
    just a thought, is the black plastic end cap loose?
    or the tan colored sleeves worn?
    I have some sleeves if so.
