Results 1 to 12 of 12
    Bearings 6002RS - 16
    From a token BB.
    Bearing marked 6002RS-16
    OD 31mm
    W 10mm
    B 16mm
    All dimensions nominal.
    Anyone got a supplier or REAL part number?
    I'm not.
    That part number has different dimensions in every part book I have looked in (to my part).
    No bearing I have been able to find fits those dimension.
    I know some other BB's use this bearing so there must be a supplier.
    Since I have checked all the big MFR's parts books I posted on here knowing some one must have an idea.
    There is little point in me quoting an incorrect part number at a shop and being supplied an incorrect part. I KNOW others have seen this but not been able to find out what they used and who supplied it.
    Reputation: cort's Avatar
    Sorry, I don't have the current CPI figures at hand for calculating the real part numbers!
    Anyhow... being serious now. I am sure you can just go to any bearing store and give them either the 6002RS-16 code, or just quote them the OD, ID, W measurements
    Negative reply from one of the specialist bike bearing suppliers. They can't get them and they are not listed in any catalog.
    Ash240,
    What B.B. do you have?
    These are the measurements you have;
    OD 31mm
    W 10mm
    B 16mm
    I'll take a peek for you tomorrow
    Token TK866CM
    "normal" bearing supplier confirmed he was also unable to get them. Got the same "oh no, that's not a problem" from him when I said they were impossible to get. That didn't last long though.
    unless someone has a source of these "special" bearings I'm going to have to fight it out with the retailer for a refund. Under a year old AND it was specifically bought to be rebuilt. Cranks are still good so I didn't want to end up not having a BB to fit them.
    Looks like I will be in the market for a new set of cranks.
    Jan 2009
    Phil wood makes a bearing #6002 but the dimensions are 15/32/9 (ID/OD/W).
    http://www.philwood.com/products/Bearings.pdf
    Yes, many others do too. I could buy them easily.
    But
    they won't fit.
    I'm really more interested in something that fits. It just seems like I would get far more use out of it if I could use it VS looking at it not fitting.
    You may also notice I have "hinted" at that part number not being correct?
    I did this as the part number is not correct. It's marked as that but is not.
    Lucky I didn't assume it was the correct part number as I would then have bought parts that don't fit. Not much good when I need a part that fits.
    I expect this whole question is about finding a supplier of a bearing that fits. Not finding bearings that don't fit
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    88500
    Return/Warranty It
    Under a year old??
    That BB should last 100 years based on it's clain that they're "special bearings" last 5-10 times longer than regular bearings.
    I've got Shimano and Phil BB's that are ~20 years old and still going strong.
    I replaced a Shimano with this. I wanted a rebuildable BB so I didn't have to change the cranks
    Do you have that part number listed by any one? NSK show it at different dimensions.
    I've found it listed with a felt seal Also some "quality" Chinese bearings but no real information or data on the size, just the part number and multiple sources show it at a different size to what I need.
    Supplier has been emailed, they told me to use the part number on there and I've explained I would rather buy a bearing that fits. Since it's under a year old if they can't come up with anything I will be pushing for a refund and either getting a new crank set (probably) or PW BB (not really cost effective for me).
    Woops, Sorry...
    I misread your dimentions
    The bearing I listed is 10x30x16
