Results 1 to 3 of 3
    May 2010
    Bearing Size for Time Z Strong
    Time ATAC series appears to take a: 696 2RS (6mm ID x 15mm OD x 5mm W) bearing. What about the Time Z Strong line?
    I believe that the Strongs are different than the standard Time Z line (which takes the same as the ATAC).
    Best,
    Mark
    May 2010
    So, QBP catalogue (for 2013) page 689 lists the 696 bearing for ATAC, Alium, HP & Z Pedals (as well as for ATAC XS Ti Carbon, XS Carbon, and XS).
    It lists (qbp part #) BB8801 for "2000 & Newer ATAC pedals" and RXS/RXE. I'm a little confused b/c I thought the 696 bearing was for the newer ATACs.
    The 8801 is a 12x21x5 (mm: id, od, w) and appears to be a "heavier duty" bearing.
    Anyway, I still don't clearly see the bearing for Time Z Strongs.
    Mark
    May 2010
    So, the Z Strong does, in fact, use the 696 bearing.
    I was having difficulty with my replacement b/c the old bearing (i.e., a destroyed, mangled pile of steel, greese, and bearing balls) left behind its inner sleeve on the needle/axle ... which, without the other axle side-by-side, made me think the bearing sets were quite different. After tearing down both side by side, I realized the mistake, extracted the inner sleeve, and put a new bearing back on.
    Best,
    Mark
  1. Time Z Strong Pedals
    By goldsoundz in forum General Discussion
    Last Post: 08-20-2013, 05:15 AM
  2. Time X Roc vs X Roc S vs Z Strong
    By lupy123 in forum General Discussion
    Last Post: 07-10-2012, 02:34 PM
  3. Feeling Strong, but slower time?
    By AlienRFX in forum General Discussion
    Last Post: 06-18-2012, 10:21 PM
  4. Time for bearing service . . .
    By 007 in forum Santa Cruz
    Last Post: 09-14-2011, 03:17 PM
  5. Bearing Size for 07 5.5
    By gottjr in forum Intense
    Last Post: 01-01-2011, 08:47 AM
