Results 1 to 2 of 2
    Bearing ?? 45-degree and 36-degree contact
    For a 36x45 bearing Which is the angle of the internal shoulder "cup" for cartridge bearing and which is for the crown race. My Look fork spec is 45-degree for the built in crown. Do I really need a 45x45; or will the stock 36x45 work?
    Thanks, I will just buy a bottom 45x45 bearing (that is Campy standard I think). FSA makes an "Orbit" 45x45 bearing; that should fit.
    FSA Orbit CF 45x45 degree 1-1/8" Headset Bearing Yellow Seal
    The first number (36) refers to the bearing to fork/centering ring interface. The second number (45) refers to the bearing to frame, or headset cup interface. If the fork specifies a 45 degree inside angle on the bearing, get one. Attempting to use the 36 degree bearing will ruin the fork. Don't attempt to change the top bearing to 45/45 and keep the original (36) centering ring. You could buy a complete headset, or just the bottom bearing, and keep the top as is.
  1. 100 mm -15 degree OPI stem?
    By the_marsbar in forum Cannondale
    Last Post: 01-25-2013, 06:12 PM
  2. What Degree Stem if....
    By LowOnO2 in forum 29er Components
    Last Post: 03-26-2012, 06:51 AM
  3. Replies: 4
    Last Post: 03-02-2012, 07:49 AM
  4. Headset to add .5 degree
    By Tjay in forum All Mountain
    Last Post: 04-13-2011, 01:11 PM
  5. 25 degree stem?
    By Esben in forum Weight Weenies
    Last Post: 02-09-2011, 08:31 PM
