Results 1 to 7 of 7
Thread: BB91 vs BB92
    bike rider
    Reputation: Lelandjt's Avatar
    BB91 vs BB92
    My frame says it has a "BB92 integrated bottom bracket".
    The crank I want says it's compatible with "BB91 press fit".
    Are these the same thing? I think Shimano started the idea of press-in bearings that work out to be the same as external cups on a 73mm BB shell. What do they call it?
    My guess is the crank company's (Lightning) website has a typo.
    Keep the Country country.
    ups and downs
    Only in bike parts and Enron accounting can 90 equal 91 or 92, Shimano call it a BB-91
    http://www.parktool.com/blog/repair-...racket-service
    but it's all the same, with variations
    bike rider
    i have the 2010 stumpjumper expert 29. It has a shimano bb-91. can i switch out the bb-91 for a sram
    bb-92 so i can have a sram xo crankset? are they the same?
    bike rider
    Quote Originally Posted by mtbcali1234 View Post
    Yes. I fact I'm pretty sure you can use the Sram crankset with the Shimano BB.
    The non drive side bearing on GXP cranksets is what holds the axle captive (hence the step in the axle) so while they will physically *fit* a shimano BB, they're not designed to be used with the BBs designed for straight 24mm spindles. Truvativ BBs are cheap as chips anyway, I wouldn't bother trying to mix and match...
    Never trust a fart
    Reputation: frdfandc's Avatar
    You can install the Sram crank in a BB92 system, but you will need the proper bearings.
    http://www.artscyclery.com/descpage-SHCRM7626BK.html
Members who have read this thread: 4
