Results 1 to 19 of 19
    Reputation: bikerboyj17's Avatar
    BB30 Crank on a BB92 frame?
    Hi all,
    I have a BB92 frame (Kona King Kahuna) and I was wondering if I could run a BB30 crankset on it. I know the e.13 crankset has a 30mm spindle and e.13 makes an adapter for BB92 frames (E Thirteen BB89.5/BB92 Adapters & Bearings | Buy Online | ChainReactionCycles.com).
    Can I use this same adapter with any BB30 crank or will I run into trouble?
    Reputation: Nater's Avatar
    I don't think it'll work. While the e.13 cranks have a 30mm spindle and will fit in the smaller-diameter shell, they also have external cups so the spindle on the e.13 cranks is quite a bit longer than the spindle on a BB30 cranks.
    Plays with tools
    Reputation: customfab's Avatar
    There are a couple of companies that make BB30 crank sets that work with standard threaded BB's but as far as I know nobody does one that works with a press fit BB shell. I doubt your strong enough to flex a 24mm spindle any way, I know I'm not.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bikerboyj17 View Post
    Hi all,
    http://www.e13components.com/setup_i.../bb_92_web.pdf
    Will let you run the e13 crank. Not for BB30 cranks.
    mtbtires.com
    Gotcha. I was just curious as I've seen a lot of good deals on BB30 cranks and wanted to be sure they weren't compatible.
    Thanks guys
    Quote Originally Posted by shiggy View Post
    Will this adapter work on an On One Lurcher frame?
    I have some e*13 cranks and want to swap them onto a lurcher.
    Dec 1998
    Quote Originally Posted by singlespeedrider View Post
    It should.
    mtbtires.com
    Perfect. I should be getting my frame later this week hopefully riding by Saturday.
    Jun 2012
    I have just installed BB30/PF30 cranks on a new Intense Carbine 27.5. It works perfectly with parts widely available in the industry.
    Because I've only 2 posts (this is my 3rd) I cannot post photos.
    It is sweet.
    Jun 2012
    PF92 with BB30/PF30 cranks
    Easy as pie.
    Brought to you by Hutch's Bicycles of Bend.
    Attached Thumbnails Attached Thumbnails BB30 Crank on a BB92 frame?-photo-1-.jpg
    Jun 2012
    ...a few more BB92 BB30 / PF30 adapter
    Smooth as silk.
    I have not ridden it yet, but clearance looks good all around, chain-line measures out perfectly.
    I'll update as soon as I put the wood to it.
    Hutch's
    Attached Thumbnails Attached Thumbnails BB30 Crank on a BB92 frame?-photo-7-.jpg
    Nov 2012
    I agree with Whitebartape.
    Nov 2012
    Cool bike
    Nov 2012
    Cool bike
    Nov 2012
    Oops, sorry for posting that twice!
    xcmtbkr
    Check out realworld cycling's website.
    They have press-fit bb92 to bb30 bottom brackets available
    Dec 2012
    i agree it, was just curious as I've seen a lot of good deals on BB30 cranks and wanted to be sure they weren't compatible.
    Jun 2012
    Remember to check spindle length of the crank before ordering!
    Oct 2012
    Quote Originally Posted by Whitebartape View Post
    Any idea what's the correct Spindle length on BB30 should be?
