    ate
    ate is offline
    Sep 2004
    BB for Turner XCE / RF Turbine
    I just picked up a square-taper Race Face Turbine crankset for my Turner XCE. I am wondering what length BB spindle will fit. Turner seems to indicate 113mm spindle w/ 73mm spacing (at least for the 5-spot, couldn't find data for the XCE), while the one compatibility chart I could find online said the Turbines needed 107-110mm, without reference to the bike. I'm a little confused by the conflicting information and want to ensure I get the right components. What BB specifications will work best?
    Thanks,
    Aaron
    Roy
    Roy is offline
    Reputation: Roy's Avatar
    113x73 is the BB you need. I have an XCE with that very crank and that's what I use.
    ate
    ate is offline
    Sep 2004
    Thank you!
    ate
    ate is offline
    Sep 2004
    More information
    By the way, Race Face says that 113mm should be used with Shimano BB's, but that their square tapers are thicker and 110mm should be used.
    I got a Shimano BB, so I should be set with the longer measurement; just thought this information might be helpful for someone else.
    Yours,
    Aaron
  1. ARGHH how do i service my RF isis BB???
    By jeb in forum General Discussion
    Last Post: 07-12-2004, 09:01 AM
  2. What's your preferred BB drop?
    By anden in forum 29er Bikes
    Last Post: 06-17-2004, 06:41 AM
  3. Replies: 16
    Last Post: 06-13-2004, 10:52 PM
  4. I'z got a BB thang goin on...
    By jrm in forum Passion
    Last Post: 04-22-2004, 08:56 AM
  5. Cranks: LX vs RaceFace Turbine LP
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2004, 04:52 PM
