Results 1 to 5 of 5
    Reputation: Deano's Avatar
    BB spacer placement...
    I just fitted an SKF BXC-600:
    http://www.skf.com/portal/skf/home/p...191011&lang=en
    It comes with a spacer for using with a 68mm BB shell (which I have).
    The instructions aren't very clear, but strongly suggest (visually) that the spacer should go on the non-drive side. This is what I've done and the crank arms look pretty evenly spaced from the chainstays, but the front mech alignment is not very good (XT) - in fact it looks like if I moved the spacer to the drive side, it'd work much better.
    Anyone got on thoughts on this?
    Cheers!
    'The Fear' is your friend...
    Reputation: GearHead's Avatar
    Dec 2004
    It would stand to reason that if you wanted the same chain line with bikes that have either a 68 mm BB shell width or a 73 mm BB shell width, you would need to put the 2.5 mm thick BB spacer on the drive side.
    I would move it to the drive side.
    There is no added value to my participation - in fact, just more confusion.
    It worked!
    Cheers, it seems to have worked a treat :^)
    Reputation: MikeDee's Avatar
    Quote Originally Posted by Deano
    Cheers!
    Where did you buy that bottom bracket? I can't find them for sale anywhere (in the US).
    I'm in the UK
    I got mine through the local Pace dealer who are bringing them in from Germany - not sure what the situation is in the US. Worth sending an email to Pace in the UK?
