Results 1 to 3 of 3
    May 2010
    BB size and chainline question (singlespeed)
    I've got a frame with a 68mm shell. Currently chainline is around 50-51mm. I'm switching my M770 cranks to one with a narrower q factor (I think), which is also a square taper (XTR M900). I don't know much about square taper BB's, so just wanted to confirm the sizing.
    If I'm trying to retain the 50-51mm chainline, I would use a 68x113 BB? I would be using the ring on the middle mount. If I'm reading Sheldon Brown's chart right, the 113 spindle lenght should give me a 50mm chainline.
    Sheldon Brown's Bottom Bracket Size Database
    Square taper guru's, please confirm. Thanks.
    A Shimano chart I have says that for a FC-M900, a 107 spindle gives a 47.5 chainline and a 113 spindle gives a 50 chainline.
    http://www.shimano.com/publish/conte...on%20Chart.pdf
    May 2010
    Great. Thanks for the link.
  1. Surly Mr Whirly singlespeed chainline?
    By lolmaus in forum Surly
    Last Post: 01-18-2013, 10:12 PM
  2. Chainline question
    By beanbag in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-08-2012, 10:28 AM
  3. KM chainline question
    By jpeto in forum Surly
    Last Post: 03-30-2012, 06:12 AM
  4. Chainline Question
    By jpeto in forum Singlespeed
    Last Post: 03-27-2012, 07:53 AM
  5. chainline/bb question
    By 918biker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-21-2011, 10:26 AM
