Results 1 to 7 of 7
    Which BB for my Shimano XTR
    Hi All
    I am getting a 2010 Epic Comp Carbon soonish.
    According to the spec sheet it has a 'Custom Shimano BB-91, OS, press-in bearing'.
    If I were to upgrade to the new Shimano XTR 2x10 speed, how would this effect my BB installation, would I need to replace, does the BB that comes with the XTR differ?
    What should I be prepared for, if I want to do this upgrade?
    Former Bike Wrench
    An XTR should be a direct fit in the existing BB on the bike.
    Reputation: crazy8's Avatar
    The BB-91 is press fit where the std BB that comes with XTR crank-set is threaded in. I think it's called Type 86 BB. Other than the way its fixed into the frame everything is the same.
    Excuse my dumb question, but if one is pressfit and the other threaded, how do both go into the same hole?
    Dec 2009
    Quote Originally Posted by philman
    I think they mean use the existing bb with xtr cranks.
    Quote Originally Posted by Q dog
    Thanks for clearing that up, I now understand.
    The BB in place should fit the new XTR and not need replacing.
    The frames BB shell doesn't have any threads and the BB cups don't have threads and the cup and bearing is press fit....like a headset.
