Results 1 to 5 of 5
    basic chain question
    For a single speed bike do I get a dedicated ss chain?
    I did search and some say that a multi speed chain is stronger.
    Yet others say that I should use single speed specific as 8 or 9 speed chains have different profile to allow for ease of shifting on the cassette.
    I would think a BMX chain would be best. Look at the stress those chains are under !
    In the end as long as I get a 3/32 pitch to match the cog and chain ring is one a better rchoice than the other?
    Reputation: joe_bloe's Avatar
    I run 8 speed chain on my SS. No durability problems, they're cheap, and I can run a widely available quick link (KMC or SRAM) to make maintenance easier.
    Reputation: J.B. Weld's Avatar
    All bicycle chains are 1/2 in. pitch, 1/8 or 3/32 refers to the width. The only reason to go with a 1/8 chain (IMO) is if your chainring and sprocket are also 1/8 in., if you use 3/32 sprockets then you are better off using a 3/32 chain because they fit the sprockets better (no side slop) and are generally much higher quality than 1/8 in. chains.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by J.B. Weld View Post
    2nd.
    You can find high quality track chains in 1/8" width though.
    Reputation: shiggy's Avatar
    Dec 1998
    My favorite singlespeed chain is the Wippermann Whitestar 108. Strong, long lasting, works fine on 3/32 rings and cogs.
    mtbtires.com
  1. Really basic tubeless question
    By Undies in forum Wheels and Tires
    Last Post: 02-18-2013, 05:24 PM
  2. Basic PRELOAD question
    By BikatronZZ in forum Shocks and Suspension
    Last Post: 11-24-2012, 11:41 PM
  3. Basic fork question
    By rtz999 in forum Shocks and Suspension
    Last Post: 02-28-2012, 07:41 AM
  4. Basic Suspension Question. HELP PlEASE!
    By s.berg in forum Beginner's Corner
    Last Post: 05-23-2011, 08:15 PM
  5. Basic Question About Cassettes
    By Apollos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2011, 10:12 AM
