Results 1 to 5 of 5
    Reputation: jclyle's Avatar
    Jun 2012
    Bashguard size help needed
    I'm getting ready to convert SRAM X5 crankset 3x10, to 1x10. I will be keeping the middle gear 33T. What size bashguard do I need? The crankset has a 4 bolt pattern. Can I use a 104x32T bash guard?
    Jun 2012
    To clarify my question, will a 32T guard be too small for the 33T gear or do I need to look at a 34 or 36T guard?
    new name, old member
    Reputation: Bike Whisperer's Avatar
    Quote Originally Posted by jclyle View Post
    The 32 will not completely cover your chain. I would actually recommend you replace the chainring with a non-ramped model. The Salsa single speed rings work with 10 speed chains.
    Single and loving it (single speed bike that is)
    http://mtnbiker72.blogspot.com/
    http://www.ccfa.org/
    Jun 2012
    If I go with a 34t single speed chainring would that work with my 10speed chain? Current chain is SRAM PC 1031.
    Yes, then get a 34t bash so the chain is protected. If you're not running a chain guide, I would also use a chain catcher, even a cheap one like the N-Gear works.
Hot Deals
Contests
Latest Mountain Bike Articles
