Results 1 to 27 of 27
    Bashguard Rubbing on Front Derailleur
    I can't for the life of me figure out how to make the Front Derailleur stop rubbing on the bashguard I just installed. Its on a 2011 Sx Trail2, if that helps in figuring it out. SLX Derailleur and 2-by front set up. Any ideas other than filing down the BG? It's rubbing on the bottom edge of the Derailleur and putting a gash into the BG.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bran12081 View Post
    Raise the FD. If you can not do that you need a smaller diameter bash.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    Is there a certain screw that would do that or do I need to take it all the way off and then put a spacer or something in?
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    Undo the clamp, and move the FD up until it does not rub. Tighten it back down.
    Ok, thanks for the help. I didn't know there was play at that angle, I will try it tonight
    I am not sure how his bash can be hitting the derailleur. My Race Face bash is only slightly bigger than the 32T ring it's protecting. The bash is smaller in diameter than the 44T ring it is replacing.
    Maybe we need a pic.
    Quote Originally Posted by MaukaRunner View Post
    Here's a couple of pics
    Attached Thumbnails Attached Thumbnails Bashguard Rubbing on Front Derailleur-photo-5-.jpg
    Dec 1998
    Because bash rings ARE larger diameter than the chainring. The stock crankset is a double and never had a 44T ring.
    mtbtires.com
    Specialized direct mount derailleur? Looks like the lower end of the derailleur is too close to the bash. My wife has a Safire but I never adjusted it yet. Can the derailleur be rotated clockwise if looking from above? The derailleur cage should be parallel to the bash if looking from directly above.
    If you rotate it in, you will need to adjust the thing again as it will pull your chain down towards the granny.
    Dec 1998
    Angle adjustment will make ZERO difference in the bash clearance. The FD just needs to be raised (if posible).
    mtbtires.com
    True, but it's protecting a 30 something ring not a 44.
    I got two Race Face ones and a Straitline and none are larger in diameter than my 44.
    From what I see in the pic the rear part of the derailleur looks to be almost a 1/4" closer than the front. If he had a triple the derailleur should clear the bash when shifting to the top. But hey, I'm not a expert, I just stayed at Holiday Inn Express.
    Dec 1998
    No, you are FAR from an expert. You are the one that brought up the 44t ring and it has no relivance here.
    His bike has never had an outer chainring nor is it designed for one.
    The bash he installed is larger than his chainring.
    When you install something larger diameter than what was there before you RAISE the FD. Period.
    mtbtires.com
    How would I go about raising it? Would there be a screw that would move the position in that direction?
    I installed the new bash guard after break the bolts on the default one in 2 weeks lol, not the best I compared the size of the old one briefly when buying it and it seemed similar in size but apparently not haha
    If you read my post, I never said he had a 44. I am saying that my bash is smaller than my 44.
    It's funny that you say I am "NOT" an expert when you don't even know who I am and I never claimed to be an expert.
    I just posted what I observed from the photo he took and it is my opinion. Perhaps he OP should take it to a real bike shop and have it fixed by a real expert.
    I'm just trying to help the guy out and I'm ending my contribution here.
    Dec 1998
    I'm just trying to help the guy out.
    Experts do not make suggestions that have no relevance to the problem and misinformation is worse than not all.
    mtbtires.com
    Dec 1998
    It is not a screw like the high/low limits.
    Look at where the FD bolts to the frame. Loosen bolts. Move FD. Tighten bolts.
    Hopefully the FD is not already at the top of the adjustment range.
    mtbtires.com
    Hey, sorry man. I guess not being a mod and having my own website makes me a dumb a$$. But hey it's cool, like I said, I'm not going to further contribute to this thread.
    Ahhhh! Good call, ok going to go try that out
    couldn't quite tell if they were at the top end of their adjustments, but I do know I am going to have to take this puppy apart again to get at them
    Dirt Deviant
    Reputation: savagemann's Avatar
    Looks like a direct mount or E-Type front derailleur.
    Some Direct mount type derailleurs DO have 2 positions that the mech can be mounted to.
    I am going to attach a couple pics below that will show you how to do it.
    As I am typing this I just remembered alot of specialized bikes DO have the direct type mount. Especially the full suspension bikes.
    What you need to do is switch the position of the little screw boss.
    As you can see, the screw hole is offset to allow 2 height positions of the mechanism.
    As it comes stock, it should be in the position of the first picture.
    You need to switch it to the position as shown in the second picture.
    The third picture is the backside of my E-Type front mech which is very similar to what you have.
    Hope this helps.
    BTW, you'll need to remove the drive side crank arm to do this.
    Also to note,
    Make sure you don't lose the washer that goes behind the derailleur for the mounting hole where it screws into the frame.
    If you look closely at the picture you can see the clean spot where the washer would be.
    This would be the left hand side bolt when looking from the drive side of the bike.
    These pictures are taken from the back side of the derailleur.
    This should give you the few mm's of clearance you need.
    Attached Thumbnails Attached Thumbnails Bashguard Rubbing on Front Derailleur-etype1.jpg
    Look, whatever happens, don't fight the mountain.
    Quote Originally Posted by savagemann View Post
    Hope this helps.
    Also to note,
    Perfect, yea, hopefully it won't be in max position, going to try it today and see what happens. Mauka sent me the manual http://service.specialized.com/colla...FSR-Manual.pdf which I never got from the dealer, so that shows the exact same thing you are referring to. Thanks!
    So took the cranks off and it turns out the screws that adjust the height are at max, so it looks like I am going to have to shave the BG down a bit with a dremel
    Before you start grinding, please check your PM.
    The slx you have is designed for a 22-36 tooth combination (if I was to guess I would say your bash's max tooth is 34). Position wise it looks like your too high if anything. The cage needs to be about 1/8th above your gaurd , where the chain meshes with the ring (note: this is true because your bash gaurd is comperable in size to the ring the derailer was designed to be used with. If it was a 44t derailer you would need to pretend there was a 44 on there. Moving the position of the derailer outside of this distance may cause shifting and chain clearance issues that make really annoying sounds and are generally bad for performance and part longevity. In other words: Shiggy should appologize for being a wiseass.
    HOWEVER, your biggest problem is the derailer mount needs to be rotated forward. That means loosening the bb cup enough to move that plate. I'm guessing that bashguard came with the bottom roller and its own plate to hold the derailler and the roller. So you should be able to fix this if you installed it because you've been here before. If not take it back to whoever did and have them fix it. Its not going to be perfect, but set up the angle so that if there were only 1/8th clearance on top there would be roughly the same towards the back end of the d cage. This will require imagination because distance wise, you going to be crazy far away, move it lower before you adjust the angle.
    If you can't adjust to get a good distance, something in the mix of plate, derailer and ring isn't right. But you can probably make it work just fine.
    Hope you haven't altered the bash already. Change this anyway as it will improve performance etc.
  1. 32/22 and bashguard - front derailleur?
    By paratrooper_72 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-05-2010, 11:49 AM
  2. Front derailleur setup w/bashguard
    By tdotrider in forum Giant
    Last Post: 05-26-2009, 06:47 AM
  3. Bashguard + Front derailleur = ?
    By RunWithScissors in forum Beginner's Corner
    Last Post: 03-21-2007, 08:06 AM
  4. Front derailleur adjustment with bashguard
    By cookie144 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-11-2005, 10:17 PM
  5. XT front derailleur rubbing
    By ToddW in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-27-2004, 01:49 PM
