Results 1 to 3 of 3
    Reputation: Justanuthabika's Avatar
    Bashguard Installation Question
    I just tried to install a saint bashguard on my xt crankset and found the head of the chainring bolts slip through the holes in the bashguard. What hardware do I need to make this work? I figured I could use the existing hardware from my cranks. I should've known better than to think that would happen!
    Meh.
    Reputation: XSL_WiLL's Avatar
    There are chainring bolts with a bigger head, or you can use a washer between the bolt head and the bash.
    The Saint bashguards are a little different for some reason.
    Reputation: JSumner13's Avatar
    I ran into the same problem a few months ago. You need to get Saint chainring bolts for it to work. I found them on ebay.
