Results 1 to 8 of 8
Thread: Bash guards
    Fox Shox
    Reputation: thredbo's Avatar
    Jan 2013
    Bash guards
    Hey guys,
    I am going to be building up a new bike soon , and was wondering whether bash guards can be mounted without sacrificing a ring. I have searched the web but can't find anything. I will be using a saint single ring crankset.
    Cheers
    If i go to hell i'm taking my mountain bike.
    BBG sells a spacer ring so you can mount a bashguard on the ring rather than the spider - but don't think it would work for the Saint. The Saint has nowhere to mount a bash.
    Products
    SPACER RING
    3MM-1/8 THICK. 10
    GRAMS. USE THESE TO
    SPACE THE GUARD AWAY
    FROM THE THIRD BIG
    RING.
    Reputation: Shalom's Avatar
    Nov 2008
    I am not sure what your question is? You are running a single ring crank, so you will not be sacrificing a ring........
    You could try a Hope IBR - chain ring with an integrated bash ring....
    Fox Shox
    Jan 2013
    Saint double ring crankset comes with a bash, but I only want/need 1 ring. If saint sold a double ring setup without a bash, I would buy that and replace the bigger ring with a bash. Or can the bash on the Saint double ring with a bash be removed? Could I just take the bash and big ring off, put a spacer where the big ring was, and put the bash back on?
    Nov 2008
    Quote Originally Posted by thredbo View Post
    So you only want the small ring?
    Yes, just use shorter chain ring bolts.
    Now you want it back?!?! Again, if you do not want the big ring, remove it, use shorter chain ring bolts and re-attach the bash ring.
    Fox Shox
    Jan 2013
    Thank you for your reply, and I apologise for not being clearer. So if I want a single ring saint setup with a bash, I should get the double with a bash, take the bash and big ring off, and reinstall bash with shorter bolts. Do I have to put a spacer in where the big ring was?
    If you buy a Saint single crankset it will come with a ring in the middle position and shaped chainring bolts that take up the outside position. I'm not sure if the normal outside ring position on the spider is machined to accept a bash or not.
    I see there is a Saint single available with a factory bash guard - not sure if you can actually buy it.
    If you buy a Saint double crankset, it comes with a bash in the outer position, a middle chainring and a granny chainring. No outer chain ring. To make it a single you would take the granny off.
    http://techdocs.shimano.com/media/te...9830728277.pdf
    http://techdocs.shimano.com/media/te...9830799256.pdf
    Nov 2008
    If I were you, I would remove the small ring and leave the big ring and bash. Part of the reason for having the bash is also chain retention. If you have a large gap between the bash and the small ring, then you will get frustrated by chain drops between the two.
  1. SRAM XO1- any bash guards available yet?
    By bugaroo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2013, 04:30 PM
  2. Bash Guards for Trek 88 and Demo's.
    By BrigRat in forum Downhill - Freeride
    Last Post: 07-02-2012, 06:01 AM
  3. Chain and bash guards
    By edgonz in forum Intense
    Last Post: 06-27-2012, 06:32 PM
  4. bash guards?
    By trekremedy in forum Downhill - Freeride
    Last Post: 05-10-2012, 03:39 PM
  5. Bash guards for Fatties?
    By fjtort2 in forum Fat bikes
    Last Post: 11-27-2011, 12:01 PM
