Results 1 to 3 of 3
    I see the line
    Reputation: mtb888's Avatar
    Bad idea to change a chain w/o cassette?
    Hi all,
    Is it really a bad idea to change my Sram chain without changing the cassette at the same time? I was told that my chain has stretched after 4 months of abuse and that I need to change the chain for smoother shifting. What do you think?
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by mtb888
    Hi all,
    If the chain's wear is not much above 1/16th of an inch over 12" you'll be ok to just change the chain. At 1/8" you will have to change the cassette too. It's all in my Chains info.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
    Reputation: ktronik's Avatar
    IMO try to get as many chains on your sprockets as you can...
    look & the smallest sprocket, if your teeth are all 'hooked' looking it may well 'skip' with a new chain... but may be OK after 4 months...
    put it on anyway... if it skips (big load) in the first sprocket only it may wear in... if it skips in more than one, most likely won't wear in & you will need a new cluster as well... worth a try for sure...
    buy the best chain you can afford...no use wrecking a good cluster with cheap chains I say...
    Ktronik
