Results 1 to 7 of 7
    Nov 2006
    Any light weight direct mounted chain keeper in place of frt der?
    I'm build up a Pivot 429 with a 1x9 drive train and I need a inside chain keeper. I've been using a jump stop on my hard tail but due to the 429 frame design it doesn't have a seat "tube" to clamp the n-gear jump stop to.
    I'll be running a light weight bash ring for outer chain protection and retention.
    Reputation: Nater's Avatar
    An e-type won't mount to a 429 either...there aren't any BB cups.
    Nov 2006
    E type refers to how the front der mounts, as in it has two bolts that screw into the frame. So what I'm looking for is an inside guide that bolts to where the frt dérailleur would normaly mount.
    I've seen the ones that mount in place of the drive side bb cup spacer. But like you said there are not screw in bb cups. So no spacer of course.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    You can always make one...
    Attached Thumbnails Attached Thumbnails Any light weight direct mounted chain keeper in place of frt der?-image-009.jpg
    Any light weight direct mounted chain keeper in place of frt der?-image-012.jpg
    Any light weight direct mounted chain keeper in place of frt der?-image-019.jpg
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Quote Originally Posted by Vortechcoupe
    ETypes go behing the BB cup as Berkley posted. What you are talking about is DMD (Direct Mount Derailleur) and I haven't seen any guide that uses this mount type.
    Check out my SportTracks plugins for some training aid software.
    Nov 2006
    Ah ok, thanks for clearing that up.
    I've seen an inner bash ring that mounts in place of the granny gear. That might work if it clears the chainstay.
    Nov 2006
    This cost next to nothing and is/should work ok. Might bend the top of the washer over the chain some more but i'll see how it goes as is.
    Attached Thumbnails Attached Thumbnails Any light weight direct mounted chain keeper in place of frt der?-img_0050.jpg
