Another front derailleur question.
Can I use a maximum 39 tooth front derailleur with a 44 tooth chain ring?
If I put these two rings together, it looks like there's not much difference in the curve where the derailleur plate moves over the ring.
Anyone with experience with this?
probably, but it might depend on your specific setup.
Here's the details. Bike is a 2011 Cannondale Scalpel. I'm looking at changing my 3X9 to a 2X9 by changing the front der and removing the granny gear. My big ring is a FSA 44T.
The front der I'm looking at buying is a SRAM X9 2x10 bottom pull S3 direct mount. The original derailleur is a SRAM X0 3X9. Basically the same except for the difference in chainring capacity.
- You may not post replies
- You may not edit your posts
Forum Rules
