Results 1 to 11 of 11
    Reputation: biketuna's Avatar
    Aerozine Crankset any good? (aluminum axle)
    They look good but I'm a bit worried about the aluminum axle.
    Anyone know anyone who broke one?
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
    Don't be hasty.
    My cranks have been fine with 4-5ft drops on my 575.
    Do you have the aluminum axle or steel?
    _______________
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    I wouldn't be worried about an aluminium axle, many cranks have them and are still very solid. LXs for instance
    Check out my SportTracks plugins for some training aid software.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Actually very few cranks use aluminium axles in the standard external bearing 24mm diameter. Most all use steel or sometimes titanium. Al flexes 3 times as much for the same spindle size as steel.
    The only ones I now about that are aluminum are the fifteen G (Hive), Specalized 30mm and the Aerozine. fifteen G and Specialized are both 30mm axles. aerozine has the 24mm.
    _______________
    Don't be hasty.
    Aluminum axle for me.
    Do you jump with yours Soya?
    _______________
    Don't be hasty.
    Did you miss my first reply?
    Reputation: AZ-X's Avatar
    Unless you are a trials rider (or know how to absorb energy as well as one upon landing), I would stay away from aluminum axles. The Aerozine cranks especially are known to flex and I've heard of a couple of them bending or cracking in the last 3 years. Granted all cranks can be broken or bent under the right circumstances, but these ones don't look particularly promising.
    Ride to Live...
    Niner MCR 9 Framest and XO Cranks w/ Ceramic BB for sale in MTBR Classifieds!
    Quote Originally Posted by Soya
    sorry I got it.
    I order the A3 aluminum one. I'm only weight 150 lbs. should drop some good weight off my SC nomad. they will be replacing stylo3.3. thanks everyone for their coments
    _______________
