Results 1 to 8 of 8
    Advice on New Crank
    Hey Guys, couple questions:
    I have to replace my crankset (due to being an idiot and semi-beginner). I have an 05 Iron Horse Warrior Expert with a FSA Gamma Drive crankset. I want something similar to this setup but maybe a bit better. I have never changed a crankset, but I know a little bit about them. I am going to have a mechanic install it, but I need to know what to buy first. I think I would like to stay with the Megaexo style BB that was used in the FSA, so I think I want to replace with something near the equivalent (barring suggestions about BB from you guys, since I am really kind of new to this). I have looked at the Race Face X-type crankset and I think I like that one and found it for a decent deal. My questions is if it will fit and what do I need to know (specifications wise) about my bike before I purchase.
    I brought this up on the beginner forumn, but I thought I might get better info here. Thanks in advance guys.
    Quote Originally Posted by jdwarrior05
    What happened to the crankset which necessitates its replacement? Broken crankarm? Bent chainring? What?...
    Depending upon the answer, it may be less expensive to simply fix or replace the broken part instead of purchasing an entirely new crankset.
    MTB B'dos
    Reputation: LyNx's Avatar
    Ditto.....
    What happened???....
    Quote Originally Posted by KevinB
    Sorry, should have specified. The non-drive side pedal threads are shot, due to cross threading. I don't even think it can be tapped for new threads. So basically, I have not leftside pedal right now, and I don't think I can find just an arm for sale. Let me know what you guys think.
    Reputation: shiggy's Avatar
    Dec 1998
    Most shops can replace the pedal threads with a helicoil. It is a common repair. Should cost you $10-20.
    mtbtires.com
    Thanks man, I will look into that. Also, you think I could get a left crankarm from FSA or maybe they would warranty the crankarm, since the bike is only about a month old or so, maybe a couple months....
    Dec 1998
    It all starts at your LBS
    mtbtires.com
    i have seen single crank arms for sale before online.
    FWIW i just got a set of race face deus XC cranks with the x-type external BB. should fit your bike if you have mega-exo BB right now. super light, stiff, and $200.
