Results 1 to 11 of 11
    Reputation: dRjOn's Avatar
    Aaron Gwin's short cage xtr m985 shadow mech
    looks like a saint ss cage has been swapped in. the techdoc exploded diagram would suggest that the cage fitting is slightly different...
    http://techdocs.shimano.com/media/te...9830676104.pdf
    http://techdocs.shimano.com/media/te...9830755929.pdf
    anyone nay further thoughts on this? id kind of like to run a 1x10 speed set up with this mech to minimise chain bounce....
    http://www.sicklines.com/2009/06/30/...ge-derailleur/
    after poking aroudn a little seems its been done witht he M972 derailleur,
    http://techdocs.shimano.com/media/te...9830721668.pdf
    but again, the pivot between the upper cage and the body of the mech seems to be a little different than on the xtr Shadow trail mech...which has the all important stabilisation switch.
    Reputation: 7HVN's Avatar
    drjon,
    Are you interested in the short cage or the "plus" part of the xtr 985 rd?
    I primarily like the "plus" part to reduce chain slap but the short cage would be good for 1X10's.
    Anybody got a time line on these bad boys? (xtr 985 plus rd)
    both. ive always preferred short cages as i ride in a lot oh heather and brush. the less cage there is the better. i also like the saint derailleur a lot: robust, strong spring, impact plate. snappy shifting too....but with xtr new shift geom, if i want to use 10 speed dyna sis, an ispec shift mount and a 1x10, a hybrid derailleur may be the only way to hit all those points....
    I just tried to do it and yes you right the saint cage fits different than M985 does, also tension spring is wider than the previous XTR der. I was decided to drill 2 lil holes in the cage to fit the spring in it when I realized i won't be able to fit the lil cage stop bolt, because the circumference of the cover won't let me. any idea?
    hello!...interesting!
    there was a video (linked via my blog) about gwin's bike at champerey - Monkey was alluding to the proto shimano parts (also brakes), and although the machined sections of the rear mech were different again, it had the clutch mechanism and a short cage - so i am assuming it is all proto saint stuff....either way it should be available 2012 im guessing?
    not the same cage that is shown in this post, that is indeed a Saint (regular cage), which tells me that can be done!
    Quote Originally Posted by dRjOn View Post
    Finally I got everything together and the xtr/saint 10sp mech works flawlessly! few things here and there needs to be done but not complicated tasks involved.
    If you need any advise to do this, please give me a shout over here.
    excellent work!.....pm sent...id love to know more....
    SLO Town
    Very nice... pm sent
  1. aaron gwin's new trek world racing dh bike
    By fixtup in forum Downhill - Freeride
    Last Post: 03-15-2011, 05:23 PM
  2. Aaron Gwin's 2010 Yeti 575
    By Danish Dynamite in forum Yeti
    Last Post: 07-17-2010, 07:46 AM
  3. Replies: 5
    Last Post: 03-14-2009, 07:55 PM
  4. Hybrid Shimano Mech - XT shadow long cage with 105 or Tiagra short cage????
    By freeride_gear in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-16-2008, 10:05 AM
  5. Ultegra Short Cage or XT Shadow Mid Cage?
    By Blaster1200 in forum Urban/DJ/Park
    Last Post: 01-25-2008, 04:22 PM
