Results 1 to 5 of 5
    9sp FD compatible with 8sp chain?
    I've unexpectedly had to order a new frame that requires a 34.9 TP, TS front derailleur. I have a stockpile of 8 speed chains and cassettes and want to use them. Problem is, it's tough finding a new 8 speed derailleur - even ebay is thin these days. Has anyone had good performance using a 9sp FD with an 8sp chain? By good performance I don't mean it simply fits in the hole and moves the chain up and down. I know it can do that. I'm concerned about constant rubbing and grinding the sides of the cage down because of the wider chain.
    alignment is critical
    I have two setups with 9sp XT FD and 8 speed Sram chain and Sram cassettes.
    I have no problem with operation in the center chainring and full range of rear cassette. I believe you might run into problems with the outer most configurations, maybe lose more than 1 cog on the rear cassette with the inner and outer rings with a little bit of chain rub which I take out with a small tweak on the cable adjuster.
    glenk
    10-4 on the alignment
    Quote Originally Posted by glenk
    That's basically what I was looking for. I run full range on middle ring a lot. I never come close to cross chaining the big or little rings, so they aren't an issue. I can appreciate how alignment would be critical though to get full range on middle ring and minimize rub on granny gear combo.
    drive train configuration
    Oh by the way,
    I run a 9speed Deore crank with my Sram 8 speed hardware on the rear. I seem to have even better (less sensitivity to alignment) when I had an 8spd STX RC crank. I think the 8speed chain wanders around a bit more on the thinner 9spd chainring. I may not have perfectly aligned teeth on my Deore center ring and I get the the slightest of chain rub if I'm pounding on the peddles (maybe flex). I guess that's what you might expect from the lower end stamped steel chain ring.
    good luck,
    glenk
    rolling in the greens
    Reputation: vermont's Avatar
    it will be no problem
    i ran a 9 sp fd on my old bike w/8 sp drivetrain with out a problem..you may have to bend it a little to keep it from rubbing the big ring...not much
  1. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  2. Can anyone really get 9sp drivetrains to work right?
    By npstaehling in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-21-2004, 02:55 PM
  3. Replies: 5
    Last Post: 06-29-2004, 10:16 AM
  4. 9sp xt fd w/8sp rings, chain & cass - incurable rub?
    By Dontgothere in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-19-2004, 07:11 PM
  5. 9sp crank on 8sp chain - will it work
    By spangelsaregreat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-04-2004, 12:45 AM
