Results 1 to 3 of 3
    Sep 2004
    9 speed shifter and 8 speed cassette?
    I am guessing that I can get this to work. Looking threw my old parts I found a number of 8 speed cassetts that I could use on a bike. I have a 9 speed shifter to use with 9 speed front chainrings. I can use a 8 speed chain on the 9 speed chainrings I think but can I adjust the der to use with the 8 chain and cassette? thanks
    Reputation: glenzx's Avatar
    Quote Originally Posted by cottonball
    No - it's the shifter and cassette that have to be a match, as the indexing on the shifter throws the rear der. a certain amount, that corresponds with a cog space / increment. The spacing for 9 speed cogs/cassettes is different than 8 speed cogs/cassettes - so it will not work.
    Assuming your asking about a 9-spd shifter and an 8-speed cassette.... which is not entirely clear from your post.
    "It's better to regret something you HAVE done, than something you haven't..." -
    Aug 2005
    you can make it work 9spd on the front and 8spd right handed shifter w/ 8spd rear casette and 9spd derailleur, but shifting on the front rings wont be optimum. you might encounter chainsuck &/or noise.
