Results 1 to 7 of 7
    8 speed chain options
    I am still maintaining an 8 speed drivetrain and have broken two Sram -pc58
    chains recently. I don't know what the problem is but I have put my chain
    back on and the link is stuck causing the chain to skip. I cannot get it to
    set up right, took out two links and the link is still stuck.
    Basically, are there any decent 8 speed chains out there? what online
    stores carry them
    Reputation: logbiter's Avatar
    Quote Originally Posted by tron
    stores carry them
    the powerlink is stuck or another link is stuck? if it's another link, try flexing that link btw your fingers & lubing it well. This was a common problem w/o using a powerlink and not getting the pin in just the right spot when re-inserting a new pin.
    I've had very good luck with pc-48/58/68 chains. Shimano w/ a powerlink has worked well too.
    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    Quote Originally Posted by logbiter
    Kind of like he said. It's very comon for a link to get frozen when reconecting a chain with a chain tool. Grab the frozen link and bend the chain sideways hard with you hands or two pairs of pliers. Also most screw type chain tools have a second inner position that will free frozen links. put the frozen link in the inner position crank down the tool on to the chain gently and it should unfreeze.
    thanks for the reply...
    Quote Originally Posted by Maida7
    I will try bending the bending it sideways tip, hopefully that will work it is really
    driving me crazy. I tried the thing with the chain tool and have still not been able to
    unfreeze it. Thanks for the replies.
    Feb 2005
    stores carry them
    I've been using Shimano IG-90 8 speed chains for 4 years now and have never broken one.Thousands of miles - never had a problem. No Power Link, but suits me fine. SRAM does a Power Link for 8 speed chains that should work on the IG-90.
    Reputation: stoked's Avatar
    whenever I use a chain tool to put on a new chain or take a link out on the trail for that emergency repair , after completing the install and pushing the pin , take out the chain tool, attach it from opposite side of the same pin and push it back for a 1/4 turn. That usually does the trick.
    Do It Yourself
    Reputation: Homebrew's Avatar
    stores carry them
    I have never had any troubles with the PC58. It sounds like you may have some other issues going on there. The PC68 is quad-peened and stronger if that's what is required.
    Long Live Long Rides
