Results 1 to 8 of 8
Thread: 8 speed
    8 speed
    Is it possible to run an 8 speed set up with nine speed front chain rings? I can't seem to find 8 speed front chain rings with 4bolts anywhere and I'm sick and tired of deal with 9speed.
    John Galt
    Reputation: cegrover's Avatar
    Quote Originally Posted by gregz12
    Yes, you can run 9-speed chainrings. You can also run a 9-spd chain with 8 cogs if you need to, but the 8-speed chain and 9-speed chainrings won't cause you problems, either.
    I just converted my wife's bike to 8-speed today (mine always was) and the shifting problems seem to be solved based on a test ride with some good shifting under load.
    Here's what I changed:
    1) Cassette - now using SRAM PG-850, 11-32
    2) Right shifter - now using SRAM 7.0 (NOS)
    3) New 9-speed Shimano HG chain (that's what I had in the toolbox)
    Here's what I kept:
    1) SRAM 9.0 rear derailleur
    2) SRAM 9.0SL left shifter
    3) Shimano 9-speed chainrings (Deore)
    4) LX front derailleur
    John Galt
    As an update, the 9-speed chain broke recently on this bike. I suspect this is due to the plates being squeezed over the cogs, which were designed for an 8-speed chain and thus are a little wider. The break occured during out-of-seat, steep climbing (probably the maximum normal load for a chain).
    I'll be running an 8-speed chain on this bike from now on. I don't anticipate problems from the 9-speed chainrings but will report back if anything is amiss there.
    So...I no longer recommend running a 9-speed chain with an 8-speed cassette!
    Reputation: Fisty's Avatar
    Hmm I learned it 9 speed teeth on 8 speed chain ok. Other way around is trouble!
    Dec 2005
    I convert my old HT to new XT 760 crankset (middle chain ring with the N'gear Jump Stop) with a XT 8 speed cassette, and a 8 speed chain. The nine speed chain is too narrow for the cassete.
    ..probably out riding..
    I used to do this all the time, no problems, works fine.
    John Galt
    You're exactly right and I think I had simply let logic escape me!
    So, to clarify because this keeps coming up:
    1) If you have 8-speed cogs and/or chainrings, you must use the wider 8-speed chain or it could break like mine did, as the wider teeth will pull apart the chain
    2) You can run an 8-speed chain on 9-speed chainrings because the wider chain can work with the narrower teeth and the front spacing is the same for 8-speed and 9-speed
    3) It's not 100% clear to me whether you can run an 8-speed chain on 9-speed cogs, as the narrower spacing of the cogs is the reason narrower chains were made for 9-speed. That being said, I've read on this forum that it will work, but I've never tried it.
    Another FYI: I installed a SRAM (PC-68) chain on the ETSX and love the powerlink! I'll be sticking with SRAM chains from now on. No more pins to buy and keep track of...
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Wouldn't Recommend #3
    Quote Originally Posted by cegrover
    Sometimes....
    I wouldn't recommend an 8spd chain on a 9spd cassette but it can work. For something like an 11-34 9spd cassette the cogs for the most part are of different enough diameter that the ramps dont catch on the slightly wider 8spd chain. On something like a 12-25 or similar "road" cassette the chain will catch on neighboring cogs and try to "shift" itself.
