    8 to 10 speed help
    Swapping from a shimano cs hg30 81 8 speed to a cs-hg62 10 speed. Got it on, and it's on there but could have a slight slight wiggle to it. Can't tell if it could be the actual free hub itself. It turns and everything, torqued up. Do I need the 1mm spacer? I've seen YouTube builds and none run the spacer..
    Says this on all the sites I checked:
    Compatible with 8/9 speed freehub bodies
    So I'm assuming it's just years of useage on the hub I have
    Reputation: J.B. Weld's Avatar
    If all of the cogs move in unison when you wiggle one of them it's the freehub, which is pretty common.
    JORBA Member
    Apr 2016
    ^ What he said lol
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Well if you had the cassette off already, you know how simple it is, so take the cassette back off, and check for play in the freehub.
  1. 11 Speed cassette, chain, rear mech and shifters with 10 speed cranks/rings.
    By devans in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2015, 01:47 PM
  2. 9 speed derailleur on a 8 speed cassette with an 8 speed shifter?
    By Nicdog911 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-03-2015, 08:29 AM
  3. 10 speed chainring with a 9 speed chain and 9 speed cassete
    By adrianfleming in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-09-2014, 11:17 AM
  4. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  5. 2 speed VS 3 speed shifter on a 2 speed crank??
    By 2000Z3M in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-18-2012, 11:46 AM
