Results 1 to 3 of 3
Thread: 7 sp. Derailer
    Reputation: onajeep's Avatar
    7 sp. Derailer
    I have a 2003 Jeep comanche and a cheap shimano sis 7 sp derailer wich i want to upgrade but im having trouble finding a 7 sp derailer thats better. can anyone help me upgrade?
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Any Current Derailleur will Work
    Quote Originally Posted by onajeep
    As long as your frame has a derailleur mount at the dropout. Derailleurs have remained basically unchanged since the advent of indexing in the 6spd era.
    Any Shimano 9sp derailleur will work
    If your frame has the derailleur hanger, instead of the cheaper bolt-on-the-axle type, any 9 speed shimano (deore or better if you have greater than a 30 tooth cassette) rear derailleur will work. It will have more travel than you need but that will be adjusted by the stop screws. The other way around won't work. The 7 speed derailleur just might not have the travel to pull the chain and shift cable over the 8/9 speed cassette width.
    glenk
  1. 7 speed rapid fire
    By Styles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-04-2004, 01:34 PM
  2. 7 speed hub, wheelset
    By Rich W in forum Wheels and Tires
    Last Post: 04-15-2004, 11:40 PM
  3. front derailer rubbing against chain???
    By dipstik in forum Beginner's Corner
    Last Post: 04-15-2004, 06:22 PM
  4. Rapid Rise derailer spring changed to
    By OffRoadRoadie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2004, 08:24 AM
  5. 9 sp rear Derailleur on a 7 sp cassette
    By saltydog73 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2004, 07:13 PM
