Results 1 to 2 of 2
    RetroGrouch
    7 --> 8-spd freehub body on early 90's LX hub?
    Here's a goofy one for you guys. I just put into service a new (old-stock) rear wheel that consists of an Araya TM-18 laced to a 92-93ish 7-speed LX hub. I've heard that the freehub body can be replaced with an 8-speed part. Is this true?
    JmZ
    JmZ is offline
    Reformed Lurker
    Reputation: JmZ's Avatar
    It can.
    Gotta tear apart the innards of the rear hub, replace the freehub body.
    Then - gotta detension and retension the rear rim to make up for spacing the wheel over a few mm's.
    Did it once already. It's possible, but not the easiest thing to do.
    Good luck,
    JmZ
    JmZ
    From one flat land to another.
    Advocate as if your ride depends on it...
