Results 1 to 2 of 2
    50 mm rear chainline is simply not possible!
    I've been meaning to do this for quite some time. I finally measured some cassettes to see what the chainline limits were. With 8 and 9 speed cassettes, it is simply not possible to have a chainline greater than 46.5 mm in the rear assuming 135 mm dropouts that are centered with the frame and 1 mm minimum clearance between the frame and cassette lockring (optimistic). It just won't fit!
    So why aren't modern cranksets available with more narrow chainlines for a better match?
    Reputation: jennasdad's Avatar
    When I was messing with cranks/bb on my bike I found the rear to be 45.5mm. I think most bb state they give a 148 chainline. Obviously there is some latitude. I found a 108, rather than the recommended 113, square taper bb gave the right front chainline. On my bike I couldn't go much less than a 146 front chainline as the inner sprocket would be touching the swingarm. So the new cranks with outside bearing approaching 150 does make one wonder.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. Light, strong 30.9 mm seatpost?
    By B R H in forum Weight Weenies
    Last Post: 08-27-2004, 02:16 PM
  3. RaceFace Deus Chainline
    By coolhandluchs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-26-2004, 02:34 PM
  4. F'ing chain keeps falling off!!!!!!!
    By liaudio in forum Singlespeed
    Last Post: 06-24-2004, 07:26 AM
  5. weight of a 50 mm thomson stem? anyone? nm
    By Biandon in forum Weight Weenies
    Last Post: 04-11-2004, 11:52 PM
