Results 1 to 12 of 12
    a.k.a. MTBMaven
    Reputation: mtnfiend's Avatar
    4mm vs. 5mm Cable Housing?
    Sorry in advance if this topic has been answered before. There are two difference size thicknesses for cable housing, I'm pretty sure the two sizes are 4mm and 5mm. Why would one go with one versus the other?
    Once I has a shop install cables on my bike before I learned how to do it myselft. They installed the thicker 5mm housing. Ever sense then I've been using the thinner 4mm.
    Old man on a bike
    Generally 4mm is for shift housing, 5mm for brake housing. The two types of housing aren't constructed the same and generally you don't want to use shift housing for your brakes (but some do it).
    suum quique
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    The last poster is wrong, there's both 4 and 5mm shift housing. Most shops will use 5mm, and there's no real good reason to have two different sizes. The 4mm will save a little weight, but the 5mm is going to be a little stouter.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
    Old man on a bike
    Guess it shows I haven't been hanging out in shops much, didn't realize most use the 5mm now. Maybe I'll get a box next time I buy shift housing...one size ferrule sounds good to me.
    suum quique
    Reputation: lebikerboy's Avatar
    Jan 2005
    5mm has been the standard since as far back as I remember. 4mm was another Shimano innovation for no good reason.
    Quote Originally Posted by Bikinfoolferlife
    Old man on a bike
    Learned something new, didn't realize that 5mm was the standard before Shimano reinvented it. While we're on the subject, do you guys recommend any particular brand or is the qbp stuff good enough?
    suum quique
    Do It Yourself
    Reputation: Homebrew's Avatar
    Jagwire makes most of the cables and housing used today. That includes QBP, Shimano, Avid and more. Generally speaking, it's all about the same and QBP works great.
    Long Live Long Rides
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Quote Originally Posted by lebikerboy
    I'm not sure Shimano "invented" this but there are more than no good reasons for it. 4mm housing does bend a bit easier. Its more flexible and easier to route easier. The inside diameter is smaller and more snuggly fits standard 1.2mm cable. 5mm housing inner diameter is slightly wider (can typically even fit brake cables). The cable is slightly loose inside and this tends to introduce some slight cable slop. Especially when the cable is bent such as turning the bar or suspension movement. It also makes it easier to use sealed rubber ends. I've never found any 5mm cable to perform as well as your average generic 4mm stuff. Generally speaking this is housing we're talking about here. There's no huge reason to jump to 4mm but there's certainly no good reason to stick to 5mm at all.
    Jm.
    Jm. is offline
    Quote Originally Posted by Hecubus
    I'm not sure Shimano "invented" this but there are more than no good reasons for it. 4mm housing does bend a bit easier..
    That works both ways though, easier to bend means it's less stout and the stiffer and stronger the housing is, the better your derailer will work and shift. I think the "better shifting" with 4mm would be a placebo effect type thing. Standard shimano housing on nice derailers and such comes as 4mm, and it usually goes on nice bikes. On nice bikes the owner usually takes the time to tune it correctly and make it work right.
    Also, don't think that all bikes are even using shift housing where they are supposed to be, cheap bikes use brake housing instead of shift housing because it costs 1/3rd the price, but it makes them perform like crap. More than a few home mechanics have used brake housing instead of shift housing as well.
    Chrome Toaster
    Quote Originally Posted by Jm.
    By easier to bend I mean it seems less likely to kink on tight turns and keep cleaner bends. That would not affect shifting (should help a bit if anything) as long as the cable remains well made and incompressible. Theres a difference between flexibility and incompresibility. I find 5mm to be more of a pain to use on bikes with weird routing or poorly placed cable stops. I don't think there is any significant difference in the internal wiring structure of the two sizes which is what makes it resistant to compression. The internal diameter on 4mm is just smaller so everything is brought closer together, to keep the cable from having play inside. 5mm is probably just a carry over from older days using the same cable diameter for brake and shifting. If you think about it there's no point any more in using cable meant for a 1.6mm? ID cable when standard shift cables are now 1.2mm.
    The Vandal strikes again
    With respect to using shift housing for brakes, this is always a bad idea. Yes, it makes the brakes feel much more firm, but it eliminates the rider's ability to modulate brake power. This effectively turns the brakes into on/off switches. The second problem is that because the shift housing cannot compress under heavy brake lever force, the housing can simply split open. It's no designed to withstand those kinds of forces. Not such a good event mid-ride. If someone is trying to make their cantilever or v-brakes feel more powerful, they should first true the wheel, then shorten the length of brake housing so that there is no excess but still enough to spin the bars around in a crash, then properly align the pads with the rim and minimize the gap between rim and pads. If necessary, replace the old housing and cable with new to eliminate drag from dirt contamination. But do not use shift housing for your brakes.
    I prefere 4mm housing on my bikes, especially my 9 speeds. Seems to be slightly more precise (not noticable on the 7/8 spd), but primarily I like it because the 4mm ferrules we have seal MUCH better than any 5mm ferrule I've seen. Wipe the cable with a little polylube or even just wipe it down with Pedro's Bike Lust and it stays nice for a while.
    Nothing against the 5mm stuff, it works fine (and like I said, especially with 7 and 8spd set ups), but I prefere the better sealing of the 4mm ferrules.
    For Sale: Cateye Triple Shot, modified with high output emitters!
  1. Replies: 23
    Last Post: 04-19-2005, 05:11 AM
  2. V brake cable & housing question
    By BigBull in forum Brake Time
    Last Post: 04-14-2005, 12:44 PM
  3. Latest on Tune or similar lightweight cable housing
    By tommasini in forum Weight Weenies
    Last Post: 01-23-2005, 10:05 PM
  4. what cables for v-brakes?
    By dansjustchillin in forum Brake Time
    Last Post: 01-15-2005, 10:51 PM
  5. Brake cable housing & more
    By Pugoet in forum Brake Time
    Last Post: 08-10-2004, 05:16 PM
