    I like pie.
    Reputation: Mr5150's Avatar
    Dec 2011
    3x9 to 2x10 Crank swap
    My old XT 3x9 crank needs to be replaced. So I am considering getting a SLX or XT 2X10 crankset. I don't want to go for a full 10sp drivetran due to $$$ and few other reasons. Will the 2x10 work well with a 9sp chain and FD? If not, I'll just go with a 3x9 crank.
    I do realize I will have to readjust the FD. Will I have to raise or lower the FD as well?
    Thanks for any input.
    Reputation: NJTransplant's Avatar
    Mar 2012
    I'm running a 3x10 front that I removed a chainring off of for a bash with the original xt 3x9 front der and a 9sp chain with 0 issues.
    Going to be doing the same in the upcoming weeks.
    Front deraileur position will be more dependent on chainring - so just high enough to clear the big ring. Then tune in the high low screws to avoid drops from overshooting shifts.
    The chain may be an issue. I think the wider 9spd chain may catch on the 2x cranks, so budget for a 10spd chain - just in case.
    believe in yourself! I believe in you!
    Reputation: PerthMTB's Avatar
    10sp chainrings have same width as 9sp chainrings
    10sp cranks have same spacing between rings as 9sp cranksets
    So, you shouldn't have an issue running a 10sp crankset with an otherwise 9sp system.
    If you are going to keep your 3x9 FD and run it with the new 2x10 cranks, don't lower it, just leave it where it was and wind in the 'H' screw so you can't accidentally shift into your (now) non-existent big ring. Yes it'll look ugly sticking up there, but if that bothers you get a 2x specific FD which has a smaller cage.
  1. SRAM 2x10 crank with Shimano 2x10 system
    By Vhom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2013, 12:42 PM
  2. Replies: 5
    Last Post: 03-18-2012, 03:25 PM
  3. should i spend the extra $100 and get the xt deore 2x10 crank over the sram x7 crank
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2012, 11:27 AM
  4. Paid Spam - SLX 2x10 drivetrain w/FSA 2x10 crank
    By mwb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2011, 03:19 PM
  5. crank arm swap
    By jrzyzombie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-16-2011, 07:44 AM
