Results 1 to 11 of 11
    Reputation: Motorider228's Avatar
    Mar 2013
    3x10 to 1x10 question
    I have a set of Shimano M552 3x10 cranks. I am looking to swap to a 1x10 set up but retain my cranks. I found a 30T, 104 BCD, 4 bolt hole chain ring. Is it as easy as swapping out the chain rings, removing the derailleur and calling it a day? Or is there more to it? If I swap that out will I be able to shift to all the gears out back without a problem? My middle ring is a 32T right now, so I am very close in size.
    thanks guys, I appreciate the help.
    Reputation: crossracer's Avatar
    Yep it's that easy. Take off your shifter, front der, and extra rings.
    Here is the big thing. Get a wolftooth chainring. It will good the chain on the ring. Also you will need bmx chain ring bolts .
    Aside from that have fun.
    Bill
    Mar 2013
    Re: 3x10 to 1x10 question
    I was looking at those and one from race face. Thanks for the reply to my noob question though, I appreciate it.
    Sent from my SGH-T999 using Tapatalk 2
    Yep, get a single speed front ring, remove the unused parts. Unless you run a bash guard you will need shorter chain ring bolts. Or shorten the nuts on your present bolts. I use a belt sander.
    Having said that, you may have chain retention issues. The single speed ring might be enough but might not.
    Mar 2013
    If I decide to run the setup as a 2x10 do I just tune my derailleur so it refuses to shift into the highest gear? Or do I have to buy those specifically for a 2x10?
    Just adjust the front derailleur limit screws so it only shifts to the middle ring.
    Mar 2013
    Cool! That's what I figured. I had a friend tell me otherwise, so I just wanted to check. Thanks guys.
    May 2012
    You might want to take a few links of your chain too
    Mar 2013
    How many links do you usually remove per tooth dropped?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Motorider228 View Post
    You have to break the chain in any case. Just resize it by the usual method.
    mtbtires.com
    I like turtles
    Reputation: TiGeo's Avatar
    If you want to run it w/o a chainguide, you will need a clutch-type rear derailleur and one of the new chainrings with teeth that help retain the chain. The rear derailleur should preferably be of the short cage variety.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
  1. 3x10 to 1X10 questions
    By kumarpr227 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-14-2013, 05:54 PM
  2. Moving from from 3x10 to 1x10?
    By ddublu in forum 29er Components
    Last Post: 12-09-2012, 08:42 AM
  3. 3x10 -> 1x10 or 2x10 -> 1x10...which is better?
    By savechief in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2012, 06:13 PM
  4. 1x9, 3x10 and 1x10 questions
    By Gokart2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2011, 01:02 AM
  5. 3x10 vs 2x10 vs 1x10
    By singletrack lover in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-01-2011, 06:53 AM
