Results 1 to 3 of 3
    Reputation: blown240's Avatar
    36t 9 Speed Cassette with 8 Speed Derailer
    I recently switchted from 8 speed rear to 9 speed rear. Im using a Deore 9 speed shifter with a 12-36 9 speed cassette. However I am still using an 8 speed XT rear derailer.
    I problem I am having is that I cannot seem to adjust the B tension screw enough to get the derailer jockey pulleys from being too close to the 36t cog.
    Am I forced to buy a new rear derailer?
    There are several things you can do. I ran into this problem using a 34 tooth cog on a 7 gear setup. Some people will put the screw in the other side this makes it a bit longer. This is a standard size screw you can get in ace hardware buy the stainless. You can put a washer between the derailer and the hanger an axle washer will work. The largest cog a Shimano derailer will climb depends on how far away from the dropout it is. You can pull the derailer back I tied the cable to the fender strut. I saw one guy use a spring connected to the rear rack. A Shimano megarange derailer will climb a 40 or a 48 tooth cog depending on the model and they are only $12. They have a lot of play so use a spoke protector. DSC02620 | Flickr - Photo Sharing!
    "Dish is illogical." Spoke of Vulcan.
    Good idea on the washer, I would have never thought of that!
  1. Will an 8 speed rear derailleur work with a 9 speed shifter and cassette?
    By CyclesnIPAs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:35 PM
  2. Zee 10 Speed Derailer on an XT 9 Speed Shifter?
    By fellsbiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-05-2015, 03:31 PM
  3. KMC X9SL Superlite 9 Speed Chain Ti Nitrate on an 8 speed cassette?
    By TheeSuperUberV in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 01:26 PM
  4. Will XT M772 rear der. 9 speed work with 8 speed shifter/cassette?
    By jh_on_the_cape in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2013, 06:40 AM
  5. 9 Speed MTB Shifters + Cassette, 10 Speed Road Rear Deraileur....??
    By joehspicer@msn.com in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2012, 08:42 PM
