Results 1 to 30 of 30
    Nov 2008
    3 Mechanics stumped- Sram xx issue
    So, I've adjusted the bike, buddy adjusted the bike, and the bike has stumped 3 mechanics at the shop so far (on two visits). So really, that's five people.
    The story: The bike is a 29" titanium hardtail fitted with sram xx 2x10 (11-36). It probably has 400-500 miles on it. It shifts flawlessly. However, while climbing STEEP grades with a lot of power (small ring front & 2nd or 3nd from lowest gear in the rear) the chain literally explodes off the small ring in the front.
    I've crashed twice so far. My left calf has a nice 6"x5" bruise from Sunday and I blew out the ass of my shorts trying to save myself. Going backwards clipped in down steep grades is sketchy. Today, while doing a test and tune, the chain came off while hammering up hill. I went over the bars and have a new gash on left shin.
    Any insight or help is greatly appreciated. I'm trying to not kill myself over this. We have a bikepacking trip planned for the Colorado trip next week.
    New Video:
    Sram XX rear derailleur problem - YouTube
    Ti flexes a fair amount. Hold the bike on the ground, and step on the crank. The bottom bracket will flex, I'm willing to bet. Whether or not that's enough to get the chain to hop off, I can't tell you, but maybe try dropping to a lower gear and not mashing so much?
    Reputation: ghettocop's Avatar
    Chainline?
    Cleavage Of The Tetons
    Yup....sounds like frame flex is essentially acting as a derailleur.
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    It's not a clutch derailleur is it? My clutch thingie engaged and caused the chain to go slack during a race last weekend and knocked my chain off the front ring (which is exactly what the derailleur is supposed to prevent)
    Nov 2008
    Chainline is good. No noises or rubbing. Shifts flawlessly.
    Oaktown Honkey on Strava
    My SIR 9 was flexy (worn out, beat down frame ), and no problem with staying on chainring, but I think that COULD be an issue. It sounds to me (without looking at it), like a worn out drivetrain. 400-500 miles of harder than usual climbing, mixed in with grit and grime from wet, and a flexible frame are conspiring against you. I have no evidence though. Jayem made an interesting point.
    Chains will climb off a cogset that has a bad plating job. I've done this for a living a badly plated parts will be sent through again. This is OK for door hinges but not for a precision part. The chain is climbing the rear cog this then creates a wave that travels to the front making it climb off as well. Shimano has videotaped gear shifting SRAM should do the same using high speed cameras.
    "Dish is illogical." Spoke of Vulcan.
    Reputation: albertdc's Avatar
    Re: 3 Mechanics stumped- Sram xx issue
    I had the same thing happen years ago - the chain would jump off the small ring under power. It turned out that it was a defective chainring. There would have been no way to see the defect or problem based on inspecting it - the shop was stumped until they called Shimano who said a recall had just gone out. They replaced the chainring and problem solved. That was a decade ago, but still proves the point that a bad thing (or possibly cassette as mentioned above) can cause your problem.
    Can you replicate it in a parking lot if you try hard enough? If so, see if your shop will be willing to test a new ring and/or cassette (one change at a time) to see if it solves the problem.
    Sent from my SCH-I535 using Tapatalk 2
    Nov 2008
    So, I think the rear derailleur is the problem. When I picked it up from the shop, they didn't really have any solutions to the problem. However, the mechanic showed my by bouncing the rear on the ground it produced a lot of chain slap and movement. He suggested that the lack of tension in the rear derailleur is causing the chain to drop.
    Sure enough, I was able to reproduce it today. While on the lower chain ring on the front and a lower gear setting in the rear, I came to a steep hill carrying a lot of momentum. As I came up the hill, without even pedaling, I hit several consecutive rock ledges and the chain came right off. The same scenario happened on another climb during the ride. No pedaling, hit some rock ledges going up hill, chain drops...
    I think the weak spring tension in the derailleur is causing the chain to excessively slap and walk off the front ring...
    A link to a similar story and potential fix:
    very weak cage tension in XX rear Der - Weight Weenies
    im no pro by any means, but all the tension is on the top of the ring. I cant see slack on the bottom cause this issue unless there is enough side to side play on the bottom of the chain.
    Level 5 Rider!
    Reputation: Desidus's Avatar
    Jun 2013
    Quote Originally Posted by machine4321 View Post
    It doesn't take much for slack on the bottom to effect/affect the top expecially on a climb when he is hitting rocks and roots. I am not at all saying this is for sure the issue, but too much slack on the bottom is definitely going to create issues. Hopefully that solves your problems rondigs.
    You earn 1000 exp!
    You are now lvl 5! (5/100)
    Str +3, Sta +4, MTB Skills +1, Grip +1, Iron Butt +1
    New Item - Broken pedals
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    I vote defective chainring. Mine did exactly the same thing, when I re-installed the small chainring backwards, after deep-cleaning it. I still have the shin scars to prove it...
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    No clutch derailleur?
    Nov 2008
    Quote Originally Posted by rideit View Post
    I don't believe it's a clutch style derailleur
    Nov 2008
    Feb 2013
    Have you checked and made sure you have no play in the bb or crank, Just a tiny wiggle that you may not even notice can pop that chain off.
    1993 Trek Multitrack 700
    2011 Trek Hifi Plus
    2013 WalGoose
    sounds like your chain may be to long if the derailleur is allowing it to jump that much.
    Seems like SRAM rd's just have durability issues
    Sent from my HTC EVO LTE
    I've had the same issue with a bad chainring as well. Silly question, is your rear wheel on there tight enough?
    Nov 2008
    Hopefully the video works:
    So, the chain has been shortened, limit screw adjusted and nothing is loose. Hopefully the video help. Also, there is no pedaling in the video, so the frame should not be under load/flexing.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    3 things I see (thou hard to tell from vid so it could be Optic illusion)
    1 rings look worn,.. like worn out
    2 Front derailleur is WAY to high
    3 Front Derailleur is to far in
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Reputation: shiggy's Avatar
    Dec 1998
    Keep your feet on the pedals while riding.
    I would bet on worn out ring and/or bent teeth.
    mtbtires.com
    Nov 2008
    The mechanic today suggested possibly replacing the big ring (due to wear). But he didn't mention the smaller ring.
    "keep your feet on the pedals while riding" Not sure what that means. I ride clipless and rarely come out. Unless the chain drops or near crash instance...
    Reputation: elcaro1101's Avatar
    Slowing the video down to .03x speed shows the bottom chain action getting worse and worse as you bounce. The cage moves 1-1.5" the first bounce and then like 4-5" the second. The chain from the top of the ring>cassette is below the chainstay and the chain from the cage>ring is almost being whipped downward by the cage action. I think this is causing it to ride off the ring from the bottom upwards.
    How does the derailleur feel with no cable/chain installed? Are you able to compare it to another possibly? Here is a picture from the second bounce with the cage almost fully extended and view of the chain as I describe above. Seems like the derailleur should do a better job keeping tension I would think, clutch or no clutch.
    Attached Thumbnails Attached Thumbnails 3 Mechanics stumped- Sram xx issue-2bounce.jpg
    Nov 2008
    So, I bought a XO type 2 rear derailleur as a replacement. When I bought it from the guy, I remembered he raced Cat 1. He told me he had the same problem with the XX rear derailleur. However, the bike shop that he is sponsored by told him they've seen this problem several times. He replaced several xx derailleurs before he switched to the XO. Now he's trying the xx1.
    The XX felt "noodlish" compared to the XO. I haven't rode the XO yet. So, not sure if it's gonna fix the issue. In the meantime, the xx derailleur is headed to sram.
    Dec 1998
    Quote Originally Posted by rondigs View Post
    Watch your own video again.
    mtbtires.com
    Nov 2008
    LOL. I'm wicked riding uphill unclipped.
    Simply a demonstration of what the bike is doing while riding...
    West Chester, PA
    You could make pretty much any bike drop the chain if you do what you did in the video. Of course the chain drops off the top of the ring when there is no tension. Not even a clutch RD will change that.
    As a former owner of one of those frames, I'm pretty certain it's the reason your chain is coming off under high loads while climbing. Mine was always a 1x10, but when I first set up the bike I tried using a ramped 32t shimano ring. No go, chain ripped right off on my first hard climb. When I switched to a non ramped ring, the chain would stay on, but I tore through 2 rings in a year. The flex was making the chain wear the sides of the teeth very fast.
    Just saw the video. Your chain is too long, by 1-2 links, or the XX RD parallelogram spring is defective. Three hard bounces should NEVER make the chain come off.
  1. SRAM X7 - Low Gear Issue
    By Usulsuspct in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-19-2013, 02:11 PM
  2. Sram shifting issue
    By WizzBang in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2013, 02:35 PM
  3. SRAM 2x10 shifting issue
    By mopartodd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-05-2013, 04:59 AM
  4. Sram Chain issue
    By mtbfyrefyter in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-22-2012, 09:42 PM
  5. SRAM X7 Friction Issue
    By LaXCarp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2012, 12:39 AM
