Results 1 to 5 of 5
Thread: 2x9 2x10 ?
    Reputation: Dwhitt1981's Avatar
    2x9 2x10 ?
    I'm looking to upgrade my bike soon and was thinking about going to a 2x9 or 2x10. I' m just woundering what the diff is. What is the benefit of a 2x9 vs 3x9? Sorry for the NOOB question. Thanks
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    Well, with 2x9, you have 18 gears, with 2x10, you have 20. Do you really need that 2 extra gears?
    2x9 is good for riders that don't need a lot of top end ( for long downhills), thats why they don't have a big ring. 3x9 is good if you have long downhills, or ride a lot of roads. With 2x9, you can put a bashguard and gain some more clearance, and you can get over logs without wrecking your big ring.
    Major difference is on a 3x9, low gear is really low(easiest to pedal). Most 2x9's are like 26x34 lowest. While 3x9's are 24 or 22x34. Unless you ride steep climbs, you should be ok with a 2x9.
    With "cross-chaining" 3x9=not 27 speeds maybe more like 22 gears. With 2x9 you have much less cross chaining...
    Well the local trails here in Guntersville have some pretty good hills. So I use the low end gears (mostly 2 front ring and 3 back ring) alot. The only reason I asked is I one of those guy that likes to try out pretty musch anything. But I didn't know what I had to gain from it . Thanks
    Mountain Man Dan
    Not all the time. You can get a Shimano non series crankset ( double ) that has 22-36 rings. I have that.
  1. Paid Spam - SLX 2x10 drivetrain w/FSA 2x10 crank
    By mwb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2011, 03:19 PM
  2. Replies: 2
    Last Post: 11-22-2010, 02:28 PM
  3. Should I go with 2x10 XO ?
    By NRS_Comp1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-02-2010, 10:08 PM
  4. 3x9 vs 2x9 or 2x10
    By adib72 in forum Weight Weenies
    Last Post: 08-18-2010, 11:46 PM
  5. 3x9 vs 2x10 - is going 2x10 going to lighten bike?
    By littlepitboy in forum Weight Weenies
    Last Post: 08-11-2010, 02:06 PM
